Using Outlook for Android in business environments for email and scheduling
Just a simple setting and Outlook settings. Just switch on the use default browser in the preference settings.
Hi, I noticed that all my links in my Android Outlook app open in an in build browser instead of the app, (such as youtube) This is really frustrating as I have to do other steps to find the option to 'Open in browser' so it then opens in the youtube app. This is for all links amazon, twitter etc.
Is there any way to disable this option? I am unable to find it in settings withtin the app.
Moved from: Options and settings / Email settings
Could you please read my reply before responding to it?
That isn't an option on my app. The play store says I have the most recent update.
And what version do you actually have?
The version I have is 4.2033.6. I know there are later versions but I can't find the update in the Play Store.
