Can't open Shared mailbox on mobile device, works on every other client.
2021-06-15T13:20:37+00:00
We want to share mailboxes with 'Least privilege' principle.
So when creating a shared mailbox instead of making users Owner we want to assign only permissions on the necessary folders.
With a PowerShell session to Exchange Online we make the following changes:
Add-MailboxFolderPermission -Identity SharedMailboxTest:\ -user ******@contoso.com -AccessRights Reviewer
Add-MailboxFolderPermission -Identity SharedMailboxTest:\Inbox -user ******@contoso.com -AccessRights Reviewer
This works fine with Outlook Web App and Outlook desktop client. We can add the shared folder and read the messages.
But when we try to add a shared folder on a Outlook Mobile client we get an error:
Authentication failed
That didn't work. You may not have the right permissions to add this mailbox or this mailbox doesn't exist.
Also added permission directly on the mailbox:
Add-MailboxPermission -Identity SharedMailboxTest -User ******@contoso.com -AccessRights ReadPermission
But that didn't make a difference.
It must be possible to delegate folder permissions. It works for default clients, but it refuses to work on mobile Outlook unless I give the user Owner permissions, but that is not 'Least privilege'.
What I'm I missing here or did I stumble on a bug in Outlook Mobile?
(It has to be Outlook mobile client on cell phones)
    2021-09-10T10:28:28+00:00
    Same problem for our company
    I already tried to remove/add my account on the app completly which did not work.
    The shared mailboxes whicht were working fine before can now not be added anymore.
    iOS Version: 14.7.1
    Outlook App: 4.2135.0 (updated on 09.09.2021)
    2021-09-10T11:51:57+00:00
    I have exactly the same issue, also got redirected to Mobile support but after providing all the info to them no reply at all.
    I've also added a new shared mailbox and this also has the same symptoms :(
    I backed up the mail in the shared mailbox and deleted it and recreated it but still no.
    I also tried connecting to the shared mailbox via MAPI as a workaround but that just immediately said unable to connect with the server.
    If anyone has a resolution to this please share as I'm stuck.
    2021-09-10T13:03:31+00:00
    Same error on our Android. I can add shared mailboxes without any issues on my PC whether it's the desktop Outlook or the OWA. Please fix this error because it's hindering our business operations!
    2021-09-10T15:24:55+00:00
    Same issue here. Outlook app on mobiles no longer works adding shared mailboxes. Same error.
    Only a licensing prohibition from MS prevents me setting a password on the shared mailbox and adding it as a new email account. Can we get clarification if MS will allow us this workaround legally in the meantime as its still broken?
    Pete
    2021-09-10T15:34:27+00:00
    Obviously not a problem, it's a feature. Please get it solved soon. The shared mailbox problem makes the mobile app worthless.
