The family calendar in Outlook.com has moved to a new Outlook.com groups calendar. This change added the ability to invite others to family group events and to use a shared family email address.
The calendar is fully supported on Outlook.com and the Outlook mobile app but is no longer supported in other applications like the Windows 10 Mail app, the Outlook desktop app, as well as some third-party apps. None of your
existing events or information were affected in the move.
We know that many of you would like to use your family calendar from other places and are actively investigating the best way to expose the calendar to a wider range of apps. You can find more details about this change and
how to use the new calendar here: Use
shared family calendars in Outlook.com.
Jad
I think we are all fully aware of the change and how the new service presents the calendars -- this doesn't help at all
this now means that a family calendar can no longer be shared Outside of the O365 web based environment - this is a massive negative on the part of this service as this means the calendar in no longer accessible from 3rd party tools and services
for example -- in our household for the last 18 months the family calendar has been presented to the Amazon ecosystem so at any point in time anyone can ask or see what is going on for the day -- also our Samsung fridge became the central point for the family
calendar and agenda, events could be seen, adjusted and added from this one location by all
With the new change all of this is now gone -- the only way to get to this calendar is to use the Outlook mobile app or web on PC
This single change has removed O365 as a viable central management tool for the family
One option I am exploring is to create a shared calendar under my own account and share - the issue is that now I cannot use my account twice on some devices and also I need to export and import all the events which without a 3rd party took is a 4 day wait
to see if anything useful comes of the 1st attempt
I talked my wife into going paperless for the family over a year ago and it was all going so well -- now she's already looking at a paper calendar -- one step forward and two steps back on the Microsoft front I'm afraid
