Trusted Platform Module has malfunctioned....
2019-04-17T08:54:32+00:00
Outlook 2016 with Office 365 account keeps prompting for password. After entering it, an error pops up "Your computer's Trusted Platform Module has malfunctioned. If this error persists, contact your system administrator with the error code 80090030. It affects Outlook login only.
2019-05-10T06:05:20+00:00
The word on the street is that Outlook is wanting MFA.  So either you have to turn on MFA or disable ADAL
Fix get them onto MFA or
Close Outlook
Open Regedit
HKEY_CURRENT_USER\Software\Microsoft\Office\16.0\Common\Identity
Create REG_DWORD
EnableADAL
0
2019-04-18T04:15:09+00:00
Hi Sam,
Based on the error message, the issue is related to Trusted Platform Module(TPM). You need to check whether your TPM works correctly. You try to back up your data and clear TPM. It will reset your security processor to its default settings. For your reference:
https://support.microsoft.com/en-us/help/4096339/windows-10-device-protection-in-windows-defender-security-center#clearTPM
For more details about TPM, you can follow the link below:
https://docs.microsoft.com/en-us/previous-versions/windows/it-pro/windows-vista/cc749022(v=ws.10)
Regards,
Carlos
120 additional answers
    2019-07-31T14:45:52+00:00
    I received this error from outlook only ( I was able to use Skype for Business, as well as email on my phone) the day after changing my AD password, but don't even have TPM enabled, let alone have one installed. Ergo, this reg. entry did nothing for me.
    On a off-chance, I logged out of all Microsoft accounts, disconnected from our LAN and connected to our Wifi, then attempted to login to Outlook.
    For whatever reason, this resolved my issue. FWIW.
    2019-08-01T06:12:51+00:00
    This worked for me... Thank You..
    2019-08-05T06:41:36+00:00
    This solved my problem with outlook. Thanks!
