Trusted Platform Module has malfunctioned....
2019-04-17T08:54:32+00:00
Outlook 2016 with Office 365 account keeps prompting for password. After entering it, an error pops up "Your computer's Trusted Platform Module has malfunctioned. If this error persists, contact your system administrator with the error code 80090030. It affects Outlook login only.
2019-05-10T06:05:20+00:00
The word on the street is that Outlook is wanting MFA.  So either you have to turn on MFA or disable ADAL
Fix get them onto MFA or
Close Outlook
Open Regedit
HKEY_CURRENT_USER\Software\Microsoft\Office\16.0\Common\Identity
Create REG_DWORD
EnableADAL
0
2019-04-18T04:15:09+00:00
Hi Sam,
Based on the error message, the issue is related to Trusted Platform Module(TPM). You need to check whether your TPM works correctly. You try to back up your data and clear TPM. It will reset your security processor to its default settings. For your reference:
https://support.microsoft.com/en-us/help/4096339/windows-10-device-protection-in-windows-defender-security-center#clearTPM
For more details about TPM, you can follow the link below:
https://docs.microsoft.com/en-us/previous-versions/windows/it-pro/windows-vista/cc749022(v=ws.10)
Regards,
Carlos
120 additional answers
    2023-03-23T15:24:30+00:00
    I was able to fix this issue by disconnecting my Work account and then reconnecting it. I was receiving the exact same error message and I had tried clearing the TPM and other fixes to no avail.
    Below are the steps I used to remedy the issue:
    1. Navigate to the “Accounts” section of the Settings app and navigate to the “Access work or school” page. Click the account you want to unlink and press the “Disconnect” button. Follow the prompts to complete the account removal process.
    2. Navigate to the “Accounts” section of the Settings app and navigate back to the “Access work or school” page. Click the "+" icon to associate an account.
    3. Enter your credentials and wait for the process to complete.
    4. Launch Outlook and all should be functioning properly.
    after trying so many potential fixes for about three days, this was the one that fixed the problem
    2023-06-23T04:42:43+00:00
    How to fix it
    2023-10-18T13:49:32+00:00
    I have a problem based on the error message Trusted Platform Module(TPM) 80090034 , my EXCEL is equally giving me a headache.
