Trusted Platform Module has malfunctioned....
2019-04-17T08:54:32+00:00
Outlook 2016 with Office 365 account keeps prompting for password. After entering it, an error pops up "Your computer's Trusted Platform Module has malfunctioned. If this error persists, contact your system administrator with the error code 80090030. It affects Outlook login only.
2019-05-10T06:05:20+00:00
The word on the street is that Outlook is wanting MFA.  So either you have to turn on MFA or disable ADAL
Fix get them onto MFA or
Close Outlook
Open Regedit
HKEY_CURRENT_USER\Software\Microsoft\Office\16.0\Common\Identity
Create REG_DWORD
EnableADAL
0
2019-04-18T04:15:09+00:00
Hi Sam,
Based on the error message, the issue is related to Trusted Platform Module(TPM). You need to check whether your TPM works correctly. You try to back up your data and clear TPM. It will reset your security processor to its default settings. For your reference:
https://support.microsoft.com/en-us/help/4096339/windows-10-device-protection-in-windows-defender-security-center#clearTPM
For more details about TPM, you can follow the link below:
https://docs.microsoft.com/en-us/previous-versions/windows/it-pro/windows-vista/cc749022(v=ws.10)
Regards,
Carlos
120 additional answers
    2023-01-21T03:32:01+00:00
    Thank you. Your solution fixed my Outlook problem.
    2023-02-13T11:34:46+00:00
    Much more annoying then the message is that when you follow the URL to go troubleshooting it says : 404 page not found !!!
    2023-03-09T09:54:17+00:00
    This fixed my issue, thank you very much Timothy_P!
