Trusted Platform Module has malfunctioned....
2019-04-17T08:54:32+00:00
Outlook 2016 with Office 365 account keeps prompting for password. After entering it, an error pops up "Your computer's Trusted Platform Module has malfunctioned. If this error persists, contact your system administrator with the error code 80090030. It affects Outlook login only.
2019-05-10T06:05:20+00:00
The word on the street is that Outlook is wanting MFA.  So either you have to turn on MFA or disable ADAL
Fix get them onto MFA or
Close Outlook
Open Regedit
HKEY_CURRENT_USER\Software\Microsoft\Office\16.0\Common\Identity
Create REG_DWORD
EnableADAL
0
2019-04-18T04:15:09+00:00
Hi Sam,
Based on the error message, the issue is related to Trusted Platform Module(TPM). You need to check whether your TPM works correctly. You try to back up your data and clear TPM. It will reset your security processor to its default settings. For your reference:
https://support.microsoft.com/en-us/help/4096339/windows-10-device-protection-in-windows-defender-security-center#clearTPM
For more details about TPM, you can follow the link below:
https://docs.microsoft.com/en-us/previous-versions/windows/it-pro/windows-vista/cc749022(v=ws.10)
Regards,
Carlos
120 additional answers
    2021-11-23T12:59:52+00:00
    👍 Thanks for the help!
    2021-12-12T19:21:25+00:00
    Close Outlook
    Open Regedit
    Create REG_DWORD
    EnableADAL
    0
    Totally worked!
    Susan Bradley - don't understand how you knew this but thank you so much. Genius!
    Andy
    2022-01-17T22:07:00+00:00
    Well,, here we are again.! Thank you Microsoft for breaking yourself once again and affecting another few million people with sloppy updates and forced programs. It appears that the Windows 11 PC checker software that gets forced onto your computer somehow breaks the TPM (Trusted Platform Module) at least for Microsoft products (as far as I can tell so far).
    Fix??? Oh, and how about providing a fix that doesn't involve an IT degree. You know.. for the masses (your target market ;)
