Trusted Platform Module has malfunctioned....
2019-04-17T08:54:32+00:00
Outlook 2016 with Office 365 account keeps prompting for password. After entering it, an error pops up "Your computer's Trusted Platform Module has malfunctioned. If this error persists, contact your system administrator with the error code 80090030. It affects Outlook login only.
2019-05-10T06:05:20+00:00
The word on the street is that Outlook is wanting MFA.  So either you have to turn on MFA or disable ADAL
Fix get them onto MFA or
Close Outlook
Open Regedit
HKEY_CURRENT_USER\Software\Microsoft\Office\16.0\Common\Identity
Create REG_DWORD
EnableADAL
0
2019-04-18T04:15:09+00:00
Hi Sam,
Based on the error message, the issue is related to Trusted Platform Module(TPM). You need to check whether your TPM works correctly. You try to back up your data and clear TPM. It will reset your security processor to its default settings. For your reference:
https://support.microsoft.com/en-us/help/4096339/windows-10-device-protection-in-windows-defender-security-center#clearTPM
For more details about TPM, you can follow the link below:
https://docs.microsoft.com/en-us/previous-versions/windows/it-pro/windows-vista/cc749022(v=ws.10)
Regards,
Carlos
120 additional answers
    2019-05-27T00:18:17+00:00
    Hi Susan,
    Can you please let me know how to enable Multi Factor?
    Thanks & Regards
    Henry
    2019-06-10T20:25:13+00:00
    I was able to fix this issue by disconnecting my Work account and then reconnecting it. I was receiving the exact same error message and I had tried clearing the TPM and other fixes to no avail.
    Below are the steps I used to remedy the issue:
    1. Navigate to the “Accounts” section of the Settings app and navigate to the “Access work or school” page. Click the account you want to unlink and press the “Disconnect” button. Follow the prompts to complete the account removal process.
    2. Navigate to the “Accounts” section of the Settings app and navigate back to the “Access work or school” page. Click the "+" icon to associate an account.
    3. Enter your credentials and wait for the process to complete.
    4. Launch Outlook and all should be functioning properly.
    2019-06-12T14:58:42+00:00
    I was getting the exact same error message when users were trying to open Office client from O365 online.  I tried everything but then found that when I changed their network profiles to roaming instead of mandatory profiles, everything started working again.
