Trusted Platform Module has malfunctioned....
2019-04-17T08:54:32+00:00
Outlook 2016 with Office 365 account keeps prompting for password. After entering it, an error pops up "Your computer's Trusted Platform Module has malfunctioned. If this error persists, contact your system administrator with the error code 80090030. It affects Outlook login only.
2019-05-10T06:05:20+00:00
The word on the street is that Outlook is wanting MFA.  So either you have to turn on MFA or disable ADAL
Fix get them onto MFA or
Close Outlook
Open Regedit
HKEY_CURRENT_USER\Software\Microsoft\Office\16.0\Common\Identity
Create REG_DWORD
EnableADAL
0
2019-04-18T04:15:09+00:00
Hi Sam,
Based on the error message, the issue is related to Trusted Platform Module(TPM). You need to check whether your TPM works correctly. You try to back up your data and clear TPM. It will reset your security processor to its default settings. For your reference:
https://support.microsoft.com/en-us/help/4096339/windows-10-device-protection-in-windows-defender-security-center#clearTPM
For more details about TPM, you can follow the link below:
https://docs.microsoft.com/en-us/previous-versions/windows/it-pro/windows-vista/cc749022(v=ws.10)
Regards,
Carlos
120 additional answers
    2020-02-27T15:45:49+00:00
    Close Outlook
    Open Regedit
    Create REG_DWORD
    EnableADAL
    0
    Thanks Susan,
    This worked!
    2020-03-20T19:47:30+00:00
    Resulted in: password window was generic (not logo as set in my Azure) and error "something went wrong with your account. asked to re-input password. it freezes and Outlook crashes.
    2020-04-16T21:40:42+00:00
    I had similar issues at my company email - an error message "Trusted Platform Module" seems to be widespread but not confirmed.  Slowed up my ability to do Webex, upon sending emails had to insert my login etc.
