Okay folks, I’ve suspected that the “upgrade” to Outlook for iOS (that Microsoft feels compelled to advertise as a default signature) caused me to lose every contact added to the iPhone native contact app since the “upgrade”, but now I’m almost certain.
I’ve troubleshot and recorded the results for every potential option here:
- Added contact to Outlook on PC. Sync result: synced to Outlook on SurfacePro, synced to Outlook.live (Outlook Cloud), synced to iPhone (native contact app) and synced to Outlook for iOS.
2. Added contact to Outlook SurfacePro. Sync result: synced to Outlook PC, synced to Outlook.live, synced to iPhone and synced to Outlook iOS.
- Added contact to Outlook.live. Sync result: synced to Outlook PC, synced to Outlook SurfacePro, synced to iPhone and synced to Outlook iOS.
Outlook 365 —> Outlook Cloud —> iCloud —> iPhone: all good.
Outlook Cloud —> Outlook 365: good
Outkook Cloud —> iCloud —> iPhone: good.
- Added contact to iPhone. Sync result: Sync failure at Outlook PC, sync failure at Outlook SurfacePro, sync failure in Outlook.live and sync failure at Outlook iOS.
- Added contact to Outlook iOS. Sync result: Sync failure at PC, sync failure at SurfacePro, sync failure in Outlook.live and sync failure at iPhone native contact app.
iCloud <—> iOS: failure
Conclusion: iCloud syncs to iPhone, but iPhone won’t sync to iCloud via Outlook for iOS, therefore, Outlook for iOS is not compatible with iCloud.
Possible Solution...
If I can find the old Outlook app I will remove “Outlook (not) for iOS” and hope that Apple didn’t discontinue the abilty to two-way sync iPhone with the old Outlook. Or, if they did, maybe “iCloud for Microsoft” will two-way sync the way iTunes did.
I’ll update 07-07-20 in the PM.
