Using Classic Outlook on Windows for personal email, calendar, and contact management
Same issue.
Raised a ticket with MS yesterday, with reference to this community string, and the mentioned support tickets.
Hi.
I have been having ongoing issues with Outlook for over 6 months, in which Outlook will become locked to the foreground.
Outlook has no add-ins enabled, and has been repaired, reinstalled, updated and downgraded many times.
The affected OS is a Windows Server 2016, functioning as a terminal server.
The affected users have two screens, and occasionally when a window is dragged to the same screen area as Outlook, Outlook will remain the foreground focus and the application being dragged will be "under/behind" the Outlook window.
This can also happen when the user is using a single screen.
This is not application specific, and even happens with the Outlook "New Email" window if popped-out from the Outlook client.
We have gathered numerous ETL logs and event logs and have come up with absolutely nothing.
Previously, the only known way to resolve the matter was to close and re-open Outlook.
However, strangely enough I have found that opening the options menu and closing it (Not changing any options, hitting either cancel or OK) will also resolve the issue.
From the options menu, we have tried with the following settings both enabled and disabled, with no luck on any setting:
We have tested the Email auto-configuration XML, and the MS partner support rep I was working with has confirmed that it is all okay.
I also provided him with screenshots of the connection status when Outlook is stuck, and we confirmed that all was OK there.
Another potential solution that was tried was unlocking and locking the taskbar. Both when the issue occurs and pro-actively.
We also recreated one of the users Outlook profile. This did not resolve the issue.
The issue is confirmed to not follow the user to other devices.
I'm sure there are more solutions that we have tried, that I have simply forgotten about during the length of this ticket.
At long last, the technician had advised me that I need to rebuild the affected server. This is not an option for us, as the server is used literally every single day inclusive of weekends, and the customer is entirely dependent on the running of this server.
I have now been advised by the technician to log a forum post here.
Please let me know if any other information should be required, but I feel this is quite extensive.
I do have recordings of the issue, and all ETL + Event logs.
Same issue.
Same issue here.
Windows server 2016/ Office 2016.
Any news on this issue?
Never resolve ^^
Microsoft for teh WIN
Same issue here on 2012 with office 2016 in terminal server environment.
Latest respond on my case with MS:
| Thursday, May 14, 2020 10:50 AM GMT |
| Hi Jesper,<br><br><br> <br><br><br>Greetings !!<br><br><br> <br><br><br>I just wanted to touch base with you in regards to the status of your case <br><br><br> <br><br><br>As I get update from Senior team the Issue is still being debugged on the Windows side.<br><br><br> <br><br><br>I'll keep post further updates with you .<br><br><br> <br><br><br>Thanks for your time and patience. |
