Sun & Moon Button Missing for Dark Mode in Outlook 365 Reading Pane
2019-10-08T17:02:11+00:00
I am using Outlook 365 1909 (Build 12026.20320) Monthly Channel. The Sun and Moon button was available in message's toolbar in Outlook for several days and now it is gone. No policies have been changed and system is restarted every evening. Microsoft Windows Version 1903 (18362.388) x64.
Thank you.
2019-10-15T17:24:51+00:00
Hi all,
The Outlook Team currently has the Sun/Moon feature enabled in Monthly Channel Production at 10% of users.  It was enabled at a higher percent earlier until a bug was found.  The team wants to fix that bug before it gets turned back on for everyone.  If I can get an ETA on the rollout I'll post back with that status.
2019-10-16T06:17:11+00:00
Hi all,
I experienced the same dark mode problem. May we know whether dark mode in outlook (with sun/moon button) is a beta feature or released feature?
If this is a released feature, why sun/moon feature is enabled in only 10% users ?
If this is in beta testing, why it is released in monthly production update?
55 additional answers
    2020-01-18T03:54:24+00:00
    Any update on when the Sun & Moon button will be available as a standard feature to Outlook?
    Hello
    Can I refer you to Gabriel Batton's post on 15 November last year which solved this for me?
    Gabriel: "From what I can tell the Sun/Moon feature is enabled 100% for Monthly Channel.  If you click File, Office Account, under About Outlook what Build and Channel do you have?
    If you are on Semi Annual Channel there are steps documented here to switch to Monthly Channel, https://docs.microsoft.com/en-us/office365/troubleshoot/administration/switch-channel-for-office-365.
    The earliest the feature would get to Semi Annual is likely July next year per channel updates page, https://docs.microsoft.com/en-us/DeployOffice/overview-of-update-channels-for-office-365-proplus.  "
    I hope that helps.
    2020-01-20T16:39:09+00:00
    Office 365 MSO is all I could find. Thanks kindly.
    PLEASE NOTE:  Your use of the subscription service and software is subject to the terms and conditions of the agreement you agreed to when you signed up for the subscription and by which you acquired a license for the software.  For instance, if you are:
    • a volume license customer, use of this software is subject to your volume license agreement.
    • a Microsoft Online Subscription customer, use of this software is subject to the Microsoft Online Subscription agreement.
    You may not use the service or software if you have not validly acquired a license from Microsoft or its licensed distributors.
    If your organization is a Microsoft customer, it has enabled you to use certain connected services in Office 365. You may also have access to other connected services from Microsoft, which are covered by separate terms and privacy commitments.  Learn more about Microsoft’s other connected services at https://support.office.com/article/92c234f1-dc91-4dc1-925d-6c90fc3816d8
    2020-02-21T20:09:53+00:00
    Edit: The symptoms below are fixed in the current version 2001.  If you're on an older version, try updating.
    I've noticed that the Switch Background/sun&moon button disappears when you have added a secondary account under File, Account Settings, Account Settings.  The message pane defaults back to a white background in this configuration.  Remove that account, close/reopen Outlook, and the button is back, and the background defaults back to dark mode again.  This is on Version 1910, build 12130.20272, monthly channel.
