Sun & Moon Button Missing for Dark Mode in Outlook 365 Reading Pane
2019-10-08T17:02:11+00:00
I am using Outlook 365 1909 (Build 12026.20320) Monthly Channel. The Sun and Moon button was available in message's toolbar in Outlook for several days and now it is gone. No policies have been changed and system is restarted every evening. Microsoft Windows Version 1903 (18362.388) x64.
Thank you.
2019-10-15T17:24:51+00:00
Hi all,
The Outlook Team currently has the Sun/Moon feature enabled in Monthly Channel Production at 10% of users.  It was enabled at a higher percent earlier until a bug was found.  The team wants to fix that bug before it gets turned back on for everyone.  If I can get an ETA on the rollout I'll post back with that status.
2019-10-16T06:17:11+00:00
Hi all,
I experienced the same dark mode problem. May we know whether dark mode in outlook (with sun/moon button) is a beta feature or released feature?
If this is a released feature, why sun/moon feature is enabled in only 10% users ?
If this is in beta testing, why it is released in monthly production update?
55 additional answers
    2020-01-18T03:52:47+00:00
    Hello
    Can I refer you to Gabriel Batton's post on 15 November last year which solved this for me?
    Gabriel: "From what I can tell the Sun/Moon feature is enabled 100% for Monthly Channel.  If you click File, Office Account, under About Outlook what Build and Channel do you have?
    If you are on Semi Annual Channel there are steps documented here to switch to Monthly Channel, https://docs.microsoft.com/en-us/office365/troubleshoot/administration/switch-channel-for-office-365.
    The earliest the feature would get to Semi Annual is likely July next year per channel updates page, https://docs.microsoft.com/en-us/DeployOffice/overview-of-update-channels-for-office-365-proplus.  "
    I hope that helps.
    2020-01-18T03:52:59+00:00
    Hello
    I hope that helps.
    2020-01-18T03:53:32+00:00
    I'm having this same issue. I use Outlook for work and school on a Windows 10 laptop and a 2013 iMac, both of which are fully updated. The sun & moon icons show up on my iMac, but not my Win10 laptop. Being that I do a lot of work at night, this issue is incredibly frustrating.
    How is it that the feature works on an Apple OS using the same Microsoft account, but not on a Windows 10 laptop? Oh yeah, and dark mode works perfectly fine with the native Win10 mail app.
    What is the point of my work AND school organization paying for the premium apps if the premium apps can't keep up with this incrediblly simple feature from the free native app?
    Hello
    I hope that helps.
