Outlook Mobile for Android Sync Settings?
2015-12-05T13:01:48+00:00
I just installed Outlook Mobile for work as my company moved to Office 365.
Here's my question, whenever I have previously used Outlook there was a setting option to sync email at specific intervals such as every 5 minutes, every hour, manual sync, etc. I can't find this setting any longer.
Where did it go? Thanks!
Outlook | Outlook for mobile | Outlook for Android | For business
2015-12-06T11:33:58+00:00
Welcome to Microsoft Community and thank you for posting your query.
I would like to inform you that the sync interval  cannot be set for the Outlook application on android phone. Outlook sync automatically whenever it is connected to internet, it can be also sync by swiping the screen downwards.
I hope the above information helps. Let us know if you need further assistance.
Thank you.
58 additional answers
    2017-11-28T08:15:04+00:00
    Totally useless applicatin without sync frequency option.
    Every other email client has this option.
    2018-01-01T17:08:28+00:00
    Guys, do you really expect Microsoft to care about their customers?! None of the big companies gives a **** about user feedback or bug fixing as long (as it doesn't impact the revenue). So don't waste your energy on tracking this and move on to another mail app.
    2018-02-07T23:12:57+00:00
    Unfortunately this very poor design choice has resulted in Outlook trying to sync every second for the last week, draining my battery and overheating the phone.
    2018-02-27T17:35:12+00:00
    Using Nexus 5x
    Android Orea 8.1
    I have the same issue and just did the following so I don't' know if it helps but go to setting>apps>Outlook>Battery Usage>Background Activity.
    There is an on-off switch, switch it to off and supposedly it won't background sync.
