Outlook Mobile for Android Sync Settings?
2015-12-05T13:01:48+00:00
I just installed Outlook Mobile for work as my company moved to Office 365.
Here's my question, whenever I have previously used Outlook there was a setting option to sync email at specific intervals such as every 5 minutes, every hour, manual sync, etc. I can't find this setting any longer.
Where did it go? Thanks!
Outlook | Outlook for mobile | Outlook for Android | For business
2015-12-06T11:33:58+00:00
Welcome to Microsoft Community and thank you for posting your query.
I would like to inform you that the sync interval  cannot be set for the Outlook application on android phone. Outlook sync automatically whenever it is connected to internet, it can be also sync by swiping the screen downwards.
I hope the above information helps. Let us know if you need further assistance.
Thank you.
58 additional answers
    2017-06-12T14:50:21+00:00
    As of June 2017, there's still no option to control syncing.  So, Goodbye Outlook for Android.  I have no need for an app that takes away sync control.
    2017-06-28T18:43:23+00:00
    A year later - this "feature" still exists.
  3. Deleted
    2017-07-24T13:37:01+00:00
    Still can't believe this hasn't been fixed....ridiculous that there is not an option to sync manually. Or only between certain times.
