"Too many simultaneous connections" error with Gmail after SP2 update
2012-04-23T09:00:02+00:00
Ever since updating to SP2, I regularly receive these errors from Outlook:
Mail could not be received at this time.
The server for account "Gmail" returned the error "[ALERT] Too many simultaneous connections. (Failure)." Your username/password or security settings may be incorrect. Would you like to try re-entering your password?
I'm connecting to my Gmail account via IMAP. As you would expect, re-entering my password as suggested by the error doesn't resolve the error and it continues to pop up every 10 seconds until I quit and re-lauch Outlook. I suspect it's something to do with the way this new version of Outlook handles multiple connections to the same IMAP server?
Is anyone else seeing this?
2015-03-13T03:37:03+00:00
from Google
If you have multiple users frequently accessing the same account or more than one IMAP client accessing Gmail at the same time, you may reach a connection threshold and receive the error message, 'Too many simultaneous connections.'
Gmail currently has a limit of 15 simultaneous IMAP connections per account.
Please note that your mail client may actually open multiple connections in the background. This means it's possible to reach a connection threshold simply by using only two mail clients to access the same account at the same time.
If you often use multiple mail clients or mobile devices with the same Gmail account, we recommend closing and/or signing out of any mail clients you're not actively using.
2012-07-12T01:52:12+00:00
Microsoft appears to have released an update that deals with this problem: http://support.microsoft.com/kb/2721015
Specifically, MS says that:
<ul><br><li>This update fixes an issue where some users who have IMAP accounts intermittently receive a “Too many simultaneous connections” error. A setting is now available to control the polling interval that Outlook uses with IMAP servers. <br><br><br><br>To adjust this setting, select <b>Tools</b>, select <b>Accounts</b>, and then select <b>Advanced </b>for the IMAP account. The setting defaults to synchronize all lMAP folders every two minutes. </li></ul>
I updated MS Office on both my iMac and MacBook Air, and I didn't change the new default synchronization setting. The iMac only occasionally had this problem, and I cannot tell if the problem has gone away completely yet on that computer.
On my MacBook Air, I had resorted to deleting my Gmail accounts as I could access them via Apple Mail desktop application and I really didn't need Outlook functions with Gmail. I started to add back my Gmail accounts, but I was getting the error message again. I turned off synchronization of IMAP folder while my mail downloaded, and the error message went away. After all my old email was downloaded, I turned IMAP folder synchronization back on (at the default 2 minutes).
It seems to have solved the problem for the most part. If you still get the error message, GMail folders may still be synchronizing, so you might have to keep hitting "No" a while longer until everything is synchronized.
So, with all due respect, it looks like it was a Microsoft problem after all. Fortunately I didn't try that time-consuming, tortuous fix recommended earlier.
I'll post an update on whether this fix has continued to work.
67 additional answers
  1. Deleted
    2012-04-30T17:30:11+00:00
    This seems to have solved my problem too - thank you. Is there a downside to disabling 'send & receive all'?
    2012-04-30T18:04:39+00:00
    The only downside I can think of is if you have other accounts within that schedule. Disabling the schedule means it never runs and so you may not pick up email from those other accounts. If this is the case, simply remove your Gmail account from the "Send & Receive All" schedule and then re-enable it.
