Unable to see contacts when I click on “To”, “Cc” or Bcc” fields to compose email in Outlook.com
2012-08-10T22:01:11+00:00
Why do my “To”, “Cc” and “Bcc” fields don’t show contacts when I’m composing my Outlook.com email?
Outlook | Web | Outlook.com | Contacts
2012-08-10T22:01:47+00:00
If you recently upgraded to Outlook.com, please wait for 1-48 hrs for the contacts to sync from your old @hotmail.com or @live.com accounts to your @Outlook.com account. Check  if you can view your contacts at contacts.live.com. If the issue exists on a different browser, we would need your assistance investigating it further.
We will need a Fiddler Trace to isolate what causes caused this problem of why your contacts do not appear on the TO/CC/BCC lines.  To capture a fiddler trace please follow the instructions below:
1.        To install FiddlerCap, visit http://www.fiddlercap.com/dl/FiddlerCapSetup.exe
 Save the file to your desktop.
2.       When the download is completed, double-click “FiddlerCapSetup.exe” on the desktop.
3.       Read the License Agreement, and then click I Agree.
4.       Click Install.
5.       When the installation is complete, click Close.
Note: FiddlerCap starts automatically.
6.       In the "Capture Options" section, enable "Decrypt HTTPS traffic".  Click OK to accept.
6.1.     If you see any security warnings about certificates, click “Yes” to allow the Fiddler certificate.
6.2.     If you see any messages from your firewall, click the option to allow access.
7.       Click 1. Start Capture.
8.       In the new browser window that opens, browse to www.hotmail.com or www.outlook.com . In this same window, reproduce the issue that you have encountered (for example, reopening a message that generated an error).
9.       After you reproduce the issue, return to the FiddlerCap window, and then click 2. Stop Capture.
10.    Click 3. Save Capture.
11.    On the Save as type menu at the bottom of this window, click Zip file (*.zip).
12.    Click Save to save the capture file to your desktop.
12.1. When exiting the capture tool, if you see a “Root Certificate Store” popup, click “Yes” to confirm deletion of the Fiddler certificate.
13.    If you have an open ticket in Mail Customer Support, reply to the message that you received from Mail Customer Support. Attach the FiddlerCap .zip file to your reply.
If you already have the copy of your fiddler trace, reply to this thread so we can give you a private message area where you can upload the logs.
Also needed:  Your new email sign in name as well as your old one.  Along with  your Operating System version AND which Internet Browser you are using.
For additional troubleshooting methods before running a Fiddler Trace you can try the following:
1.  Clear your internet browsers cookies/cache, sign out and sign back in and try to reproduct the issue.
2.  Try using a different browser and let us know if the results change.  Note:  If you're running IE7, there is a known issue where the email addresses won't populate.  If you are on IE, try upgrading to IE8 or higher.
3.  If you're able to try on another computer, does the issue still happen?
Please make sure to keep this thread on track with this issue.  Any other issue that does not deal with what the subject is will be removed or deleted.
Thank you
60 additional answers
    2012-08-25T07:42:02+00:00
    Thanks Ryniel,
    I did what you suggested to Marc Battesti in your last paragraph and it worked finefor me.  I did not attempt anything else before that papagraph, but I am now back to normal and can use all my contacts.
    Many thanks!
    Bernard D_866
    2012-08-27T10:22:16+00:00
    Hi Ryniel,
    I can't view my contacts by going to  http://people.live.com. I only see the new contacts I created after the issue.
    I kepp my browsers updated and, after testing it, my problem appears on all the browsers so it seems not to be the problem.
    I can't access to your link  http://profile.live.com/contacts?bfv=um
    I didn't upgraded my browser by following your steps yet because, like it's said upper, my problem appears on all the browsers I tested (IE8, Chrome last version, Firefox). Let me know if you consider useful to do it anyway.
    I tried to turn on HTTPS settings but my contact list is unfortunately still empty.
    I will try to access to your second link from home tonight.
    Waiting your feed back.
    Best regards.
    Marc
    2012-08-27T14:01:17+00:00
    Hi, I did the Fiddler Trace and I have 1E8.  Can you send me the insturctions for uploading the log and correcting this issue?
    thanks
    Rachelle
    2012-08-27T17:35:08+00:00
    You have got to be kidding me!! Why didn't you just leave it as it was?  Now I can't add any new contacts and have them show at the "To" mark when I send a new email.
