Problems when using contractions such as I'm, I'll, etc. Any help?
2012-07-04T04:34:34+00:00
I'm having a problem whenever I try to use contractions that begin with "I" - such as I'm, I'll, etc. When I type "I'm", I get "I'  M" followed by a beep. Same thing with "I'll" - Outlook will type it as "I' L" and beep, not allowing me to enter any new characters until I delete the old and I have to type "I am" or "I will". "I've" is also a problem. It's seems as if the auto spell checker is just choking on any contraction beginning with "I"?
Yes, I am running the latest developer version of Mountain Lion but I've been running it for months with no problems in any Office app. This is something new and totally off the wall.
Any suggestions?
Clinton
2012-07-28T04:59:25+00:00
Final update:
Update to Mavericks to resolve this issue.
The problem is related to webkit.  Webkit is a component of OS X (it is the HTML rendering engine behind Safari).  The bug was reported to Apple shortly after this thread started.  The fix was released recently in the version of webkit included with Mavericks.
As a temporary workaround please turn off the "Capitalize first letter of sentences" autocorrect setting.
Select the menu Outlook, Preferences, Autocorrect and uncheck "Capitalize first letter of sentences".
Update:
The recent Mac Office 14.2.5 release did not contain a fix for this issue.
The problem is related to webkit.  Webkit is a component of OS X (it is the HTML rendering engine behind Safari).  The bug was reported to Apple shortly after this thread started and we are eagerly waiting on a fix.
Apple released version 6.0.2 of Safari early November 2012, including a webkit update.  It is that update which is causing people to see changed, but not fixed, behavior.
The particular test case I have been using to reproduce the problem still fails with Safari 6.0.2.  Other uses are reporting that situations which were broken before now work.
There is no benefit in trying new identities or new user accounts.  The issue is well understood as being a webkit regression from when Mountain Lion was released.  It is not related to any problem with your identity, account or installation.
The above temporary workaround is still the only solution to suppress the problem until a complete webkit fix is released.  Updating to Safari 6.0.2 through Apple Software update may address some situations.
90 additional answers
    2013-04-02T20:58:28+00:00
    I should've added that it makes no difference whether I set Entourage to write in HTML or Plain text.
    2013-04-08T04:38:08+00:00
    Hi Scott,
    I'm experiencing this problem now with my newly purchased Office 2011. In particular when I type I'm, it's correcting to I'M, or I've to I'Ve, etc.
    I would prefer not to have to turn off first letter capitalization because that is a useful feature.
    Any progress on a bug fix?
    -Brendan
    2013-04-08T06:58:42+00:00
    Dear Scott,
    I know it's an old thread for you, but for me the problem is new and restricted entirely to Entourage 2008 with my own User ID. Just wanted to say, I don't think it's purely a webkit problem - in a different test user set up there is no problem with the capitalization of just one letter ("M") after an apostrophe. All the workarounds and instructions for switching preferences on and off, changing autocorrect etc don't work. I get the feeling it is some sort of autocorrect that is invisible to me that's causing it in my main user ID. Would it be possible to make a comprehensive checklist of all the parts of the system and apps where auto-corrections might have been set - so I can systematically eliminate them all?
    Update:
    2013-04-22T21:37:15+00:00
    Thanks for informing that this is a Webkit regression bug, that explains and helps a lot.
    However, I find the solution of unchecking Autocorrect's "Capitalize First Letter of Sentences" to be a little heavy-handed.  Sometimes when scrawling out emails, I appreciate the capitalization help.
    An alternate solution to this exact error of caps after I' such as in "I'd, I'm, and I'll,"  I have a leaner solution:
    Get to the same Autocorrect section of the preferences dialog. (CMD+,)
    Click "Exceptions"
    Click the "First Letter" tab up top.
    Click the "+" sign on the bottom, and add I' to the list.
    When you close this, you'll have added the case of I' to items for which you don't want the succeeding letter to be capitalized.  Simply put, I'd, I'm and I'll will all type properly now, and won't yield I'D, I'M and the nightmarish I'Ll.
    Thanks!
