Problems when using contractions such as I'm, I'll, etc. Any help?
2012-07-04T04:34:34+00:00
I'm having a problem whenever I try to use contractions that begin with "I" - such as I'm, I'll, etc. When I type "I'm", I get "I'  M" followed by a beep. Same thing with "I'll" - Outlook will type it as "I' L" and beep, not allowing me to enter any new characters until I delete the old and I have to type "I am" or "I will". "I've" is also a problem. It's seems as if the auto spell checker is just choking on any contraction beginning with "I"?
Yes, I am running the latest developer version of Mountain Lion but I've been running it for months with no problems in any Office app. This is something new and totally off the wall.
Any suggestions?
Clinton
2012-07-28T04:59:25+00:00
Final update:
Update to Mavericks to resolve this issue.
The problem is related to webkit.  Webkit is a component of OS X (it is the HTML rendering engine behind Safari).  The bug was reported to Apple shortly after this thread started.  The fix was released recently in the version of webkit included with Mavericks.
As a temporary workaround please turn off the "Capitalize first letter of sentences" autocorrect setting.
Select the menu Outlook, Preferences, Autocorrect and uncheck "Capitalize first letter of sentences".
Update:
The recent Mac Office 14.2.5 release did not contain a fix for this issue.
The problem is related to webkit.  Webkit is a component of OS X (it is the HTML rendering engine behind Safari).  The bug was reported to Apple shortly after this thread started and we are eagerly waiting on a fix.
Apple released version 6.0.2 of Safari early November 2012, including a webkit update.  It is that update which is causing people to see changed, but not fixed, behavior.
The particular test case I have been using to reproduce the problem still fails with Safari 6.0.2.  Other uses are reporting that situations which were broken before now work.
There is no benefit in trying new identities or new user accounts.  The issue is well understood as being a webkit regression from when Mountain Lion was released.  It is not related to any problem with your identity, account or installation.
The above temporary workaround is still the only solution to suppress the problem until a complete webkit fix is released.  Updating to Safari 6.0.2 through Apple Software update may address some situations.
90 additional answers
    2012-11-14T19:27:11+00:00
    A partial fix in my case. Reverting to automatic capitalization of the first letter of the first word works for new sentences subsequent to the first one in a new document. Entering a lower case first word in a new Outlook plain text email has the following result:
    > non-contraction: upon depressing the space bar or adding punctuation, the first letter is capitalized and the cursor is sent to the bottom of the document (end of email signature in my case). This behaviour doesn't occur in subsequent sentences.
    > contractions (excluding those starting with I'): upon entering the apostrophe, the first letter is capitalized and the cursor is sent to the bottom of the document.
    > lowercase contractions without an apostrophe are auto-corrected, but the first letter is not capitalized.
    Close, but not quite there. Too bad.
    2012-11-14T20:53:39+00:00
    It's fixed for me but it seems not for everyone.
    Could I get you to do two tests for me. Trying to locate why it's working for some not others.
    1. Test in a new Identity. This will tell us if it's your Identity.
    2. Test in a new User. This eliminates issues in your User folder.
    Verify that you are updated to the latest OS X.
    10.8.2
    10.7.4
    10.6.8
    [Added comment November-15-2012] Testing in a new Identity will not fix this issue. However it might fix other issues you are seeing that are directly related to the Identity. Scott_MSFT replied on November 14, 2012 that the issue is with Safari's WebKit.. See his post for more details.]
    2012-11-14T21:17:53+00:00
    Just did a full test for contractions. Here is what is showing for me:
    http://www.flickr.com/photos/dianeross/8186318658/
    2012-11-15T00:50:40+00:00
    Complete removal of Office 2008 and 2011 in accordance with MS published protocol; reinstalled, reactivated and updated 2011; downloaded newest version of Outlook from Exchange host and installed, followed by more updating...then tested for issues.
    After a length first run setup, Outlook appears to be performing much better than before without the emergence of the dreaded spinning kaleidoscope of colour. However, the odd correction problem remains with the cursor being sent to the bottom of the page after the first letter in the sentence is corrected. Entering a contraction without the apostrophe autocorrects for the latter, but doesn't capitalize the first letter of the word.
    Testing with a new identity does not yield the same results: the cursor relocation is eliminated, but the first letter of autocorrected contractions does not get capitalized. HOWEVER, I am reluctant to move to using a new identity because one of my email accounts is a POP account and I will lose access to that database in the new identity. Any solution for that? The only way I can think of doing it is to remove my Exchange, iCloud and Gmail accounts, exporting the remainder (assuming that would leave only the database of POP mail) and importing it into the version using the new identity.
    I appreciate your assistance with this to date.
