Using older versions of Outlook for Mac in business environments
I also encountered the same problem... any ideas... genius microsoft developers...
I'm having a problem in syncing my hotmail e-mails through IMAP on Mail for mac.
I've followed the steps in **How to set up Mac Mail to sync your Outlook.com account**to set up my mail in Mail for mac and it seemed to work. The initial sync worked fine, but then after I tried to copy/paste a load of my old POP3 mail from the same hotmail account into the IMAP mailbox, I have started to get issues where Mac Mail never finishes sync'ing. I now have had no new email land in my inbox for 5 days ! :-(
All the folders under the inbox and all the other mail items such as sent, drafts, junk etc are synchronising but none of the new e-mails in the inbox are showing up.
Can someone please guide me as to what this issue could be and how to fix it ? I keep occasionally getting the "error 9" messages that other people have received, but mainly I just see the 'activity monitor' sat there saying "Synchronizing with server" for hours on end and then it appears to stop.
The inbox currently has around 3.5k mails inside, but I have approx 7k I still need to *copy* into this mailbox from my old POP3 mailbox archive.
I have tried shutting down mail and deleting the .OfflineCache folder as per certain blog posts, but to no avail. I have also tried to offline/online the account as well as "enable/disable" the account from inside Mac Mail preferences.
Mac OS X v10.8.5
Mac Mail v6.6
Any help is very much appreciated.
***Post moved by the moderator to the appropriate forum category***
I encounter the same issue. please help microsoft team.
following error message is shown, when moving mails into subfolders:
An attempt to read data from server „imap.glbdns2.microsoft.com“ has failed.
It's increasingly apparent that Microsoft is either unwilling or incapable of fixing this problem. GMAIL works fine and as expected. Hotmail/Outlook does not.
Until such time that Microsoft corrects the problem, one may use Thunderbird client instead of Mac Mail provided that a modification to the CONFIG EDITOR is made. One must change the following EXPUNGE command lines from FALSE to TRUE
mail.imap.expunge_after_delete;true
mail.imap.check_deleted_before_expunge;true
These changes tells the Outlook servers that a message has been moved or deleted immediately upon such action.
One caveat: Thunderbird does not "play well" with Mac OS X Contacts. It cannot add or append contacts directly to the OS X Contacts program.
MICROSOFT...PLEASE...FIX YOUR IMAP CONNECTION ASAP!
I'm having the same issue, and also occasionally a new one in regards a UID Server issue while deleting emails.
Please help us to solve this issue Microsoft team.
Regards
Hello Everyone,
Thank you for posting and I'm sorry for the late response.
Please be informed that this thread has been escalated to support specialist. You may create your own thread so a moderator can assist you as soon as possible.
Regards.
