where have all my contacts from hotmail gone
2013-03-31T21:26:38+00:00
WHERE HAVE ALL MY HOTMAIL CONTACTS GONE?
Outlook | Web | Outlook.com | Contacts
2013-03-31T21:29:35+00:00
In Outlook.com contacts ARE people...To access People from Outlook.com, hover the cursor over the Outlook logo in the top left and click on the down-arrow that appears to the right of the Outlook logo.
Select People.
Returning to your Inbox from People:
Hover the cursor over the People logo and click on the down-arrow that appears on the right of the People logo. Select Mail.
You can also get to Calendar or Skydrive in the same manner.
Filtering your list:
Above the search box at the top of the Contact list on the left, is a filter option which says "All ".
If you click on this you should see the groups you created in the past.
Click on any of these to filter your list to just the contacts in that group.
Selecting one or many Contacts:
If you click on a contact name in the list, the details for that contact will appear on the right.
Alternatively, if you click on the check box to the left of the contact picture, you can build up a list of selected contacts on the right by clicking on the check box to the left of multiple contacts.
Adding/Removing from Group membership:
Whether you select one or many contacts, you will see a top menu bar option for Groups.
If you click on this, then it will display the list of groups with a check box checked for each group that the contact(s) is/are a member of.
You can uncheck to remove or check to add, the selection of contact(s) to the chosen groups, and then click on Apply to apply the changes.
Your selected contacts will then be updated to be added or removed from the groups you chose as appropriate.
Delete
When you select one or many contacts, you will see a top menu bar option for Delete.
If you click on Delete and click Delete in the confirmation box, the selected contacts will be deleted.
Edit:
You can choose edit if you have clicked on a single contact (name or picture) in the list on the left to see their details on the right.
When viewing their details, click on Edit in the top menu bar to edit or add details.
Browsers:
We recommend that you keep your web browser up to date to get the most out of the People experience.
If you’re not using an updated browser, some parts of People might not work and it might not display properly.
59 additional answers
    2013-04-01T06:51:41+00:00
    yes I have tried to user a different browser I normally use firefox and have tried using IE but still no contacts
    2013-04-01T08:49:35+00:00
    Thank you.
    For the best experience, you should **update your browser** to the latest version and make sure the newest version of **Microsoft Silverlight** **is installed** and running for browsers that support it.
    Outlook.com is optimized for the following browsers: Windows Internet Explorer 8, 9, and 10; Google Chrome 17 and higher; Firefox 10 and higher; and Safari 5.1 on Mac.
    Outlook.com is good on the following browsers**, but some features might not display properly**: Internet Explorer 7, Google Chrome 16 and 5, Firefox 9 and 5, and Safari 5.1 on Windows or Safari 5 on Windows and Mac.
    Outlook.com isn't supported on the following browsers: Internet Explorer 6 and older, Google Chrome 4 and older, Firefox 4 and older, Safari 4.x and older.
    2013-04-01T10:50:59+00:00
    I use latest versions of all browsers and all security updates but again my problem is that my contacts are not on OUTLOOK
    I am not stupid I know how to operate a browser and how to find things; my contacts have not been moved to OUTLOOK
    2013-04-01T18:30:37+00:00
    FYI > This site is not Microsoft.
    It is a peer to peer site staffed mostly with volunteers who have little or no contact with Microsoft.
    We appreciate that everyone must have their email "fixed" NOW, and we do our best to expedite them as efficiently and professionally as possible.
    Unfortunately, at times, our best efforts don't meet with success.
    A Forum Moderator MAY be able to help you further.
    Thank you for your patience.
