SOLVED: SMTP not using AUTH even when configured
2020-07-30T18:15:43+00:00
When I configure an account with IMAP and SMTP, both with SSL/TLS and authentication, I cannot send emails and messages get bounced by the SMTP server "Server error: '554 5.7.1 <recipient@example.com>: Relay access denied". Tested this on Office 365 (2007 build 13029.20236) and Office 2019.
During configuration, Outlook tests the configuration and succeeds. I get the standard "Microsoft Outlook Test Message" in the account's mailbox. In the logs on the SMTP server, I can see the authentication taking place.
Jul 30 17:50:22 smtp postfix/submission/smtpd[22037]: connect from 192.0.2.191.dynamic.example.net[192.0.2.191]
Jul 30 17:50:23 smtp postfix/submission/smtpd[22037]: Anonymous TLS connection established from 191.232.111.77.dynamic.example.net[192.0.2.191]: TLSv1.2 with cipher ECDHE-RSA-AES256-GCM-SHA384 (256/256 bits)
Jul 30 17:50:23 smtp postfix/submission/smtpd[22037]: 5EBD2CC75: client=191.232.111.77.dynamic.example.net[192.0.2.191], sasl_method=LOGIN, sasl_username=smtpaccount
Jul 30 17:50:23 smtp postfix/cleanup[23907]: 5EBD2CC75: message-id=<>
Jul 30 17:50:23 smtp postfix/qmgr[82376]: 5EBD2CC75: from=<recipient@example.com>, size=1141, nrcpt=1 (queue active)
Jul 30 17:50:23 smtp postfix/submission/smtpd[22037]: disconnect from 191.232.111.77.dynamic.example.net[192.0.2.191] ehlo=2 starttls=1 auth=1 mail=1 rcpt=1 data=1 commands=7
Jul 30 17:50:24 smtp postfix/lmtp[24544]: 5EBD2CC75: to=<recipient@example.com>, relay=smtp.example.com[/var/run/dovecot/lmtp], delay=0.72, delays=0.36/0.01/0.04/0.31, dsn=2.0.0, status=sent (250 2.0.0 <recipient@example.com> 9bP8K18II1/9YAAA8Ew+PQ Saved)
Jul 30 17:50:24 smtp postfix/qmgr[82376]: 5EBD2CC75: removed
When sending a regular from the account, I can see in the logs that Outlook is NOT using authentication. No sasl_method is found in the logs.
Jul 30 18:08:43 smtp postfix/submission/smtpd[26518]: connect from 191.232.111.77.dynamic.example.net[192.0.2.191]
Jul 30 18:08:44 smtp postfix/submission/smtpd[26518]: Anonymous TLS connection established from 191.232.111.77.dynamic.example.net[192.0.2.191]: TLSv1.2 with cipher ECDHE-RSA-AES256-GCM-SHA384 (256/256 bits)
Jul 30 18:08:44 smtp postfix/submission/smtpd[26518]: NOQUEUE: reject: RCPT from 191.232.111.77.dynamic.example.net[192.0.2.191]: 554 5.7.1 <@gmail.com>: Relay access denied; from=<recipient@example.com> to=<@gmail.com> proto=ESMTP helo=<DESKTOPCE8EISJ>
Jul 30 18:08:47 smtp postfix/submission/smtpd[26518]: disconnect from 191.232.111.77.dynamic.example.net[192.0.2.191] ehlo=2 starttls=1 auth=1 mail=1 rcpt=0/1 quit=1 commands=6/7
Can someone please explain to me how I force Outlook to use SMTP AUTH for this account?
Thanks! Barnerd.
Microsoft 365 Insider | Outlook | Other
2020-08-03T09:43:56+00:00
SOLVED
Ultimately turned out to be a configuration problem in Postfix. Postfix not logging the successful AUTH when the mail is rejected made me look at the wrong place to fix this!
When I enabled verbosity for submission in the master.cf (submission -v) the logs showed successful AUTH and a reject on the recipient address.
The smtpd_recipient_restrictions configuration was missing the permit_sasl_authenticated option. After adding permit_sasl_authenticated it worked as desired.
0 additional answers
