A professional diagramming tool that helps users visualize complex information through easy-to-understand diagrams.
Thanks Shashank it worked :)
Want a quick overview of the Data Visualizer feature?
Updated:3/23/2018
Hello Insiders,
We've some very useful feature updates for you!
First, Visio Data Visualizer now supports bi-directional synchronization between the Excel data and the Visio diagram. Now keep both files synchronized and up-to-date, when you change the Excel data, refresh the diagram; when you change the diagram content, update the Excel data.
Where can I find these options?
Once you have created your diagram from data, click anywhere inside the diagram to enable the Data Tools Design tab in the ribbon***.***In this tab, you will find the following entry points (as shown in image below):
For more details read through Stage 6: Synchronizing the data and the diagram in this article.
Second, now create Data Visualizer diagrams using any stencil of your choice! The shape mapping step of the Create from Data wizard allows you to select more shapes now. More details here.
Updated: 9/27/2017
Hello Insiders,
We've got a cool feature update for you, now enhance your Data Visualizer diagram by adding data graphics! Visualize the key metrics in your process map Excel data using Visio data graphics. For example, notice how an analyst can overlay the process step cost and owner information on the diagram using data graphics as follows.
Note: To use the Apply Data Graphics to Data Visualizer diagram feature in Visio Pro for Office 365, you must be an Office Insider.
Updated: 5/22/2017
We've got some great feature updates for you! The following new Data Visualizer feature enhancements are available in app version 16.0.8067.2115 (or above):
Thank you for all your feedback, it really helps us in improving the feature. We invite you to try it out once again and let us know if there are any other improvements we should make.
I am Shashank Gandhi, and I work as a Program Manager for team Visio at Microsoft. Back in October 2016, we released an early preview of the Data Visualizer feature in Visio. We created this feature for those of you who would like to present your process map requirements captured in Excel in a structured format, and automatically convert those to diagrams. This helps with:
We’ve received some fantastic feedback on the Data Visualizer feature (referred to as Visio smart diagrams earlier) from Insiders. Your insights have been invaluable for us as we continue to make improvements on this feature. As our valued Insider, we are pleased to share with you a first look at the improvements we’ve made since we announced this feature last fall.
You can get a quick overview by watching this video:
What's improved since the last Insider preview?
We’ve added several new features based on asks from our Insider customers --
Availability
To preview the Data Visualizer feature, make sure you've checked the following --
Scenarios to try
a) Creating a diagram from data in Excel
In the Create a Diagram from Data wizard, click Browse, and navigate to the Excel file you just created for the process steps. All diagram mappings will get pre-populated.
b) Refresh your diagram
Note:
c) Export as a Template Package
Once your diagram is created, share it as a template package with others in your organization. The template package enables users to share the diagram and associated data file together with the diagram mappings preserved in the template itself!
Create mappings once and re-use them across your organization
Send us your feedback
Did you hit any rough spots, have suggestions for improvement, or looking for more ways to automatically create any other diagram types? We’d love to hear from you! You can leave a comment on this post or send us an email at <dv-feedback[at-the-rate]microsoft.com>
Have any other feature ask for automatic creation of diagrams from data? Post your suggestions/ ideas at
Visio User Voice.
Thank you!
Shashank Gandhi and team
Resources
Create a Data Visualizer diagram
Morten,
Great! However, just want to highlight that the layout gets reset when you Refresh the diagram. If you intent to use Refresh functionality (that is Refresh your diagram when you make changes in Excel) then please make the following change:
Please note that this is an interim workaround, we will be fixing this such that you can change layout from Design tab and settings are preserved.
If you face any issues, please reach out at <dv-feedback[at-the-rate]microsoft.com>
Shashank Gandhi
PM, Visio
I have an office 365 subscription account and I also have Visio 2016 Pro +
Why am i not able to use the Data Visualizer? I am not able to see the 'excel data template'.
Many Thanks
Hi Phil,
What version and build of Visio are you currently running? You can find that information under File > Account, and looking for the number that looks like "Version xxxx (Build xxxx.xxxx Click-to-Run)"
-Jesse
