PPT not working properly MacBook pro M1 Chip
2021-07-22T11:03:54+00:00
My PPT on my macbook air M1 does not work right.  Many of the buttons (indent, bullets, insert text box) just dont work, and i cant copy and paste graphics from one slide to the next, or Group objects.   is there some major issue with PPT functions on an M1 chip?
Microsoft 365 Insider | PowerPoint | MacOS
A family of Microsoft presentation graphics products that offer tools for creating presentations and adding graphic effects like multimedia objects and special effects with text.
  1. Deleted
    2023-11-28T16:02:42+00:00
    I can't edit the ppt if i download from google
  3. Jim G 134K Reputation points MVP
    2023-09-26T14:30:47+00:00
    First, ensure your installation is up to date.
    Here's the current beta channel update level:
    If you're not in the beta channel, then you've posted your question to the wrong forum. The forum for non-beta channel questions and comments is here:
    https://answers.microsoft.com/en-US/msoffice
    2023-09-26T14:07:52+00:00
    I am experiencing problem with my Microsoft powerpoint on MacBook Pro M1 chip.
    I can not use presenter view and text keeps on disappearing from the slides and when I move slides forward and backward then it re appear again. moreover I can't turn on the video as well on my power point slides, which was perfect earlier. I recently bought this laptop and transferred my MS office from old to this new laptop.
    I'll be grateful if you can help in this regard.
  5. Jim G 134K Reputation points MVP
    2022-03-22T02:32:02+00:00
    Hi
    You have a different version of PowerPoint than what was discussed in this thread. Please start a new thread with your symptoms and version information. The replies here do not apply to your situation.
    Thank you.
