Error: MDX Function failed because its current coordinate is empty
2018-04-05T06:49:35+00:00
Hi All,
I have
Microsoft SQL Server 2014 (SP1-GDR) installed in one of the servers. It is R&A server. Every day once cube refresh completes and when the user or us try to access the reports the cube becomes unavailable and gives the error: "MDX Function failed because its current coordinate is empty".
But the strange part is this issue doesn't appear again when we restart the analysis services and then we are able to access the report.
Could you please help in analysis this issue as this seems to be the issue with the analysis services?
Thanks in advance,
Hina
Microsoft 365 Insider | Install, activate, and update | Other
    2018-04-05T17:23:50+00:00
    Hi Hina,
    Your best bet for getting forum help would likely to be to post on the MSDN SQL Server forums
    -Jesse
