A family of Microsoft spreadsheet software with tools for analyzing, charting, and communicating data.
I am not seeing this behavior. Excel 16.95, MacOS Sequoia 15.3 (24D60).
Since updating Excel for MAC to 16.95, when I use ⌘+C and ⌘+V for copy/paste, it only pastes the values and not the formulas. And after using these commands, when I press on Enter, the cursor does not move down. But it works fine before using the ⌘+C and ⌘+V shortcuts...
Is anyone having the same problem?
Thank you
Ok, thanks to you both
It's important to report problems immediately as the are occurring. Use the Menu Bar and choose Help > Feedback > Report a Problem.
I did report the problem. I am on MAC OS 15.1.1
I think Mac OS 15.2 is available. Why not install it and see if that corrects the problem?
