Excel double click to AutoFit is not working with new worksheet and no wrap text or merged cell.
2018-12-04T00:55:01+00:00
My Excel when I create a new sheet just to prove its not working or when working with a saved file, when I double click the column or roles to auto fit nothing happens.
Wrap Text is not enable and merged cells are not used either.
I created a new sheet with no merged cells and no wrapped text on.
I then wrote something shorter than the width of the cell so I can check to see if it works and nothing happens.
Can anyone help me?
Many thanks,
Danny
Microsoft 365 Insider | Excel | MacOS
2018-12-20T21:52:10+00:00
I just wanted to let everyone know that I fixed the problem! The problem was caused by my mouse speed that was set to the highest double-click speed, under preferences/mouse. I decreased the speed to half and now its working double clicking to auto fit in excel again.
Thank you
7 additional answers
    2018-12-10T12:33:47+00:00
    Hi guys, thank you.
    None of this helped, so I guess I will have to format my computer and see if it works.
    2019-01-27T00:41:04+00:00
    Worked for me. Genius :)
    2019-01-27T02:39:06+00:00
    glad it worked for you! this was very annoying for me and I thought it was Excel's problem. I found the solution by mistake. lol
