Excel double click to AutoFit is not working with new worksheet and no wrap text or merged cell.
2018-12-04T00:55:01+00:00
My Excel when I create a new sheet just to prove its not working or when working with a saved file, when I double click the column or roles to auto fit nothing happens.
Wrap Text is not enable and merged cells are not used either.
I created a new sheet with no merged cells and no wrapped text on.
I then wrote something shorter than the width of the cell so I can check to see if it works and nothing happens.
Can anyone help me?
Many thanks,
Danny
Microsoft 365 Insider | Excel | MacOS
2018-12-20T21:52:10+00:00
I just wanted to let everyone know that I fixed the problem! The problem was caused by my mouse speed that was set to the highest double-click speed, under preferences/mouse. I decreased the speed to half and now its working double clicking to auto fit in excel again.
Thank you
7 additional answers
  1. Jim G 134K Reputation points MVP
    2018-12-06T16:18:03+00:00
    Hi Danny,
    Yours is the first report I've seen about this.
    Did you try simply restarting your Mac?
    2018-12-04T17:02:55+00:00
    Hi, thank you for the feedback.
    All files have the same problem and even If I open a new one. It won't work and I did the procedure you gave me, but still no success.
    Here is my excel version and IOS.
    I have just created a new excel file and wrote ddd and double clicked it on top to see if would auto fit, but no. I am also experienced using excel and this feature is something I use a lot, but for some reason it is not working.
    Many thanks
    Hi Danny,
    We are more than willing to help you figure it out.
    Based on my test, we can use AutoFit feature.
    To clear the situation, I need to confirm if you have tried the following steps to check the result:
    1. Select all the column.
    2. Put the mouse on the border of the column.
    3. The following icon will occur:
    1. Then you can double click to use AutoFit.
    If the issue still exists, could you please provide the following information?
    1. The OS version and Office version. (Click Excel>select About Excel)
    2. Check if all files meet the issue.
    3. Can you use it before? Which operation have you taken before the issue occurred, such as updating Office?
    Regards,
    Qing
    2018-12-04T10:09:59+00:00
    Hi Danny,
    Regards,
    Qing
