Compile error in hidden module: link using Word for Mac 15.24 (160707)
2016-07-18T10:54:15+00:00
I have recently update to the "slow insider" 15.24 version of Word for Mac 2016 and am now getting this error when launching or trying to quit Word. If you OK the message it goes away, but a) why is it now doing it? b) does it affect any functioning c) what is : link that it is referring to d) when will it be fixed?
Microsoft 365 Insider | Word | MacOS
John Korchok 235.9K Reputation points Volunteer Moderator
2016-08-31T23:34:44+00:00
Just substitute your user name for ComputerName and UBF8T346G9.Office for "******(ID# assigned during install).Office", then insert User Content before Startup/Word. So the complete path will be Users/YourUserName/Library/Group Containers/UBF8T346G9.Office/User Content/Startup/Word, though apparently some installations append .localized to some folder names.
28 additional answers
  1. John Korchok 235.9K Reputation points Volunteer Moderator
    2016-08-15T01:08:57+00:00
    You can probably trash it. Acrobat will have to re-install the file in a future update. If you're concerned, you can save the file until the next update in case it's absence causes a hiccup.
    2016-08-15T01:44:22+00:00
    Thank you for your help!
