How can I fix the notification banner position for the new Microsoft Teams?
2023-10-23T01:17:29+00:00
I just installed the new Microsoft Teams and I noticed that the notification banner is displaying a bit off. It would be great if it were displayed in the lower-rightmost part of the screen (just like from the Teams classic).
Thanks.
    2023-10-23T10:14:23+00:00
    Hi Alex,
    Thank you so much for your reply.
    Unfortunately, I don't see any "Banner and email" section from my New Teams' Settings > Notifications and activity.
    I can only see General, Chats and channels, and Meetings. Are there any other ways to set that up outside the Teams client?
    Also, could this be controlled by our organization? If so, I don't think there's anything I could do (and that's fine).
    In case you need to know, the Teams version I have is 23272.2707.2453.769.
    Cheers,
    Ed.
    2023-10-23T06:37:58+00:00
    Hi, Ed-A
    Good day!
    Thank you for posting to Microsoft Community. We are happy to assist you.
    Accroding to your description, to change the position of the notification banner in the new Microsoft Teams, you can follow these steps:
    1. Click on your profile picture in the top right corner of the Teams app.
    2. Select "Settings" from the drop-down menu.
    3. Click on "Notifications" in the left-hand menu.
    4. Scroll down to the "Banner and email" section.
    5. Under "Banner notification position," select "Bottom right" from the drop-down menu.
    This should change the position of the notification banner to the lower-rightmost part of your screen.
    Let me know if you have any further questions or issues!
    Thanks for your attempts and looking forward to your new updates.
    Hope you all the best!
    Sincerely,
    Alex | Microsoft Community Moderator.
