No notification banner or sound on Microsoft Teams desktop app for Mac
2023-09-01T08:25:00+00:00
I use the Microsoft Teams desktop app on my Macbook. No matter what I do, I cannot get the app to play sound or show a banner for notifications in the app. This problem is being experienced by the other members of my team, who also use the desktop app on Mac.
I am using this version of Teams: Microsoft Teams Version 1.6.00.22155. It was last updated on 2023/08/17.
This is the OS that I’m using: macOS Ventura 13.5
I would love to include screenshots but Microsoft answers won’t upload my images! It says “upload failed” each time, without even partially uploading. Guess what - can’t find the solution to this on answers either. So, here is a written description of what I can see in my settings on the desktop app:
Under settings -> appearance and sound: "show message preview” and “play sound for incoming calls and notifications” are both toggled on.
Under settings -> appearance and sound -> chat: the options for @mention, @Everyone, Messages, and Likes and reactions are limited to “Banner and feed”, “Banner” or “none”. There are no options for sound.
I tried looking at teams.microsoft.com in my browser (Chrome for Mac) to see if I got different settings options there but they look exactly the same as the options on the desktop app.
The banners don’t show up at all and it seems that though I should be receiving sound on notifications, I can’t actually receive that sound? Which is very frustrating. I have a second screen that I work on everyday, so sound is the notification setting that I am most reliant on - if I’m not looking at my laptop screen and don’t see a banner, the notification sound is critical (assuming that the banners for notifications begin to appear, which they currently don't).
I have tried finding a solution to this online and I am having no joy. Please can someone assist me. Also, let me know if you can figure out why I can’t upload screenshots - I tried two different browsers and hard refreshed multiple times. I used different image extensions (.png and .jpg). I then gave up.
2023-09-01T12:54:49+00:00
Okay well this is embarrassing. It’s a very simple solution.
For all your Mac users, Apple has decided that no app will determine the notification settings. Here’s what you do to fix those settings:
Open your System settings, identified by the cog icon.
System settings -> notifications -> Microsoft Teams
Toggle “Allow notifications” to on.
That’s it. That’s what worked for me. Currently very glad I did not use my name when posting this question.
Hope this helps.
56 additional answers
    2024-07-22T14:37:23+00:00
    Hope this helps.
    What also helped me was clicking "Allow Notifications when MIRRORING or sharing the display" because I'm docked to 3 monitors..and none of my teams notifications were displaying correctly until that. Thanks so much for the help
    2024-08-06T12:04:52+00:00
    If you are too frustrated because of not receiving MS Teams notifications, don't worry! I've figured out how to fix it.
    Here's how you can fix it:
    1. Check Microsoft Teams Notifications in System Preferences:
      • Ensure Microsoft Teams notifications are enabled in System Preferences.
    2. Check MS Teams Settings:
      • Make sure notifications are enabled in MS Teams settings.
    If all settings are correct and you are still not receiving notifications, then check if your Focus mode (Do Not Disturb) could be enabled and blocking the notifications. Follow the steps below to allow it:
    • Go to System Settings > Focus > Do Not Disturb > Allowed Apps
    • Add MS Teams inside the allowed apps
    This should resolve the issue, and you should start receiving notifications from MS Teams again!
    2024-08-13T17:55:03+00:00
    yeah, i tried this solution after doing hell lot of research. I can say is the ulimate solution for notification/sound issue in Teams. Thanks @Adrian Tristan for posting this trick which made my life easy in work time. I reallly had bad experience by missing team notifications though I am in front of Desktop.
    2024-09-04T14:21:27+00:00
    Hey Adrian
    You are a life saver. The trick was that Focus setting and it worked like a charm.
