Surface Pro 8 camera issues caused by Teams and New Teams
2023-11-02T17:38:27+00:00
My Surface Pro 8 has always had the issue of the camera not responding after joining a Teams session, then a Zoom or Google Meet session and then a Teams session again. With the new Teams App, the problem is much worst since it manages to mess up the camera by itself; I could be in the middle of a Teams session and the camera just freezes. The problem does not go away until I reset the computer. If I place it on stand by mode, Windows cannot activate the camera when I wake it up, it takes a reset to make the camera work again.
I have seen numerous post from other users with the same problem and all I have read as an answer form Microsoft is to update drivers or firmware. I hav done that multiple times, in fact, I just did again and the problem persists. Will look for a way to get back to the previous Team desktop application to make life bearable for a bit.
I will appreciate any assistance.
Here is all my device info:
  • Información del dispositivo:
  • Nombre del dispositivo: SURFACEP8-CHM
  • Número de serie: 0F00YK2214401J
  • Modelo de Surface: Surface Pro 8 Model 1983 i5
  • SAM: 11.200.139.0
  • UEFI: 22.103.143.0
  • Versión de la app: 61.23100.116.0
  • Versión o fecha del BIOS: Microsoft Corporation 22.103.143 08/06/2023
  • Controlador Wi-Fi: 22.190.0.4
  • Edición: Windows 11 Home
  • Compilación del sistema operativo: 22621.2428
  • Procesador: 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
  • RAM instalada: 8 GB
  • Tamaño de almacenamiento: 19 GB free of 237 GB
  • GPU: Intel(R) Iris(R) Xe Graphics
  • Resolución de pantalla: 2880 x 1920
Regards,
Ciro H.
    2024-02-13T21:32:13+00:00
    Hi Simon,
    I am pretty certain the problem is with the Surface Pro camera drivers and any web application that uses the camera. I have made sure nothing else is running while using the New Teams app and the issue still ocurs. However, I will go through the steps that you suggest while the latest drivers download.
    1. Not anymore, I removed Teams from the list of applications that start automatically.
    2. None of them were running. I started the new Teams App and it is the only one running.
    3. Zoom starts an App on my computer whenever I start a session. It does not run automatically on startup. Google meet I use it 100% web based.
    4. No application has used it other than Teams during the past 48 hrs,
    I will install the new drivers in a bit (assuming they are not already installed) and give it a try.
    Regards,
    Ciro
    2024-02-13T23:37:18+00:00
    Thanks, I just installed it. Will let you know if it solves the issue.
    Regards,
    CH
    2024-02-23T08:09:34+00:00
    I'm having the same problem - zoom has been an ongoing issue but now with Teams it isn't working at all! It freezes instantly and then just switches off. I can't get it to work even if I restart and have everything else shut down.
    2024-02-23T15:52:59+00:00
    Hi Sola,
    Thanks for the advice. Unfortunately, it did not help. The problem is not triggered only by the New Teams app, it happens whenever I use a web app that uses the camera, such as Google Meet, Zoom or the New Teams app.
    All of my camera drivers are up to date (front, rear, IR) and I have also downloaded and installed the lates Surface firmware and drivers. It seems a dead end.
    My next step is to try an external USB camera and see if it works fine. Also, I am discouraging any person I know from buying a Surface Pro table. I was an avid fan and have passed my previous versions to my kids.
    By the way, mi daughter's Surface 7 Pro has the exact same issue.
    Regards,
    Ciro
    2024-02-23T15:54:54+00:00
    Regards,
    CH
    Hi, just to let you kbow that installing the lates Surface Pro 8 driver pack did not solve the issue.
    Regards,
    Ciro
