Surface Pro 8 camera issues caused by Teams and New Teams
2023-11-02T17:38:27+00:00
My Surface Pro 8 has always had the issue of the camera not responding after joining a Teams session, then a Zoom or Google Meet session and then a Teams session again. With the new Teams App, the problem is much worst since it manages to mess up the camera by itself; I could be in the middle of a Teams session and the camera just freezes. The problem does not go away until I reset the computer. If I place it on stand by mode, Windows cannot activate the camera when I wake it up, it takes a reset to make the camera work again.
I have seen numerous post from other users with the same problem and all I have read as an answer form Microsoft is to update drivers or firmware. I hav done that multiple times, in fact, I just did again and the problem persists. Will look for a way to get back to the previous Team desktop application to make life bearable for a bit.
I will appreciate any assistance.
Here is all my device info:
  • Información del dispositivo:
  • Nombre del dispositivo: SURFACEP8-CHM
  • Número de serie: 0F00YK2214401J
  • Modelo de Surface: Surface Pro 8 Model 1983 i5
  • SAM: 11.200.139.0
  • UEFI: 22.103.143.0
  • Versión de la app: 61.23100.116.0
  • Versión o fecha del BIOS: Microsoft Corporation 22.103.143 08/06/2023
  • Controlador Wi-Fi: 22.190.0.4
  • Edición: Windows 11 Home
  • Compilación del sistema operativo: 22621.2428
  • Procesador: 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
  • RAM instalada: 8 GB
  • Tamaño de almacenamiento: 19 GB free of 237 GB
  • GPU: Intel(R) Iris(R) Xe Graphics
  • Resolución de pantalla: 2880 x 1920
Regards,
Ciro H.
    2024-02-03T03:09:32+00:00
    I have the same problem, if it's not resolved I will have to contemplate buying a laptop but based on the same issues w newer versions of the Surface Pro, it won't be a Microsoft product. Ridiculous to have this level of issues with a laptop that's a year old.
    2023-12-13T15:29:47+00:00
    Same issue here. I have rolled back to the previous Teams and now it works fine just in Teams. I have issues with Zoom and Google Meet. I have found that if I don't switch between apps when I'm on a video conference the camera works fine, but if I switch the probability that camera freezes are very high.
    All drivers are up to date.
    2024-02-23T15:52:59+00:00
    Hi Sola,
    Thanks for the advice. Unfortunately, it did not help. The problem is not triggered only by the New Teams app, it happens whenever I use a web app that uses the camera, such as Google Meet, Zoom or the New Teams app.
    All of my camera drivers are up to date (front, rear, IR) and I have also downloaded and installed the lates Surface firmware and drivers. It seems a dead end.
    My next step is to try an external USB camera and see if it works fine. Also, I am discouraging any person I know from buying a Surface Pro table. I was an avid fan and have passed my previous versions to my kids.
    By the way, mi daughter's Surface 7 Pro has the exact same issue.
    Regards,
    Ciro
    2024-01-31T16:43:49+00:00
    Same issue here. The camera stops working in the middle of a teams meeting. I see a white screen for the camera pane and the others in the meeting see my video as a frozen image.
    2023-11-30T02:05:46+00:00
    same issue here on Surface Pro 8.
    have tried all steps to resolve.
