Using Whiteboard in MS Teams Breakout Rooms
2023-02-09T11:35:30+00:00
Hi, I have used the Whiteboard tool during Teams calls, and I would now like to use it with students in breakout rooms if possible.
As the owner of the whiteboard, will the master version be copied through into each room so that the groups are working on the same version, or do I need to create sub-versions that are brought back to the main call to discuss?
If it is the same version for all groups, will this mean that for example, Group 1 will be able to see what Group 2 is doing?
Thank you
Microsoft Teams | Microsoft Teams for education | Meetings and calls | Whiteboard
    2023-02-09T12:17:24+00:00
    Hello! My name is Janbaz, and I am an Independent Advisor.
    I'm sorry to hear you're having this problem, and I hope I can assist you to find a satisfactory solution.
    Please check the below article related to your issue:
    1. Use breakout rooms in Teams meetings
    Source: https://support.microsoft.com/en-us/office/use-...
    You can share a new/existing whiteboard with all participants in a Teams meeting. That same whiteboard is available across all devices.
    You can also choose an existing whiteboard to share in a Teams meeting.
    1. Share a whiteboard in Microsoft Teams
    Source: https://support.microsoft.com/en-us/office/shar....
    Warm Regards,
    Janbaz
