My Airpod pro 2 doesn't work on Teams
2023-09-21T11:34:36+00:00
My Airpod pro 2 doesn't work on Teams. They have no problem with other programs, and also work on teams on my phone.
They connect fine and I can see that they are selected in the teams settings. The app is also on the list of apps that can access the microphone and so on.
Furthermore I have disconnected them and reconnected them several times, I have also deleted Teams and installed once agin. Nothing works!!!!
It works fine otherwise and with other headphones.
Microsoft Teams | Microsoft Teams for business | Teams for Mac
2023-10-30T18:46:54+00:00
I spent 2.5 hours yesterday doing allll of the steps I've found in every forum and I think rolling back the intel bluetooth driver worked for me. I did a test run with teams, Settings > Devices > Make a test call, and everything worked for the first time since this all started a few months back. I havent had an actual teams call to test it but this is promising. I think some things work for some people, and others work for some, its not a one fix works for all type of thing.
Windows Key + X > Device Manager > Bluetooth > Intel Wireless Bluetooth > Driver > Rollback Driver. Restart Windows. I also restarted my airpods before I rebooted, and re-connected them to windrows to have a clean slate on both accounts. Then made my test call with teams and it worked.
104 additional answers
    2023-10-08T11:32:12+00:00
    Same issue actually. It's frustrating to say the least having spent and realising you can do one of the important jobs in day to day life
    2023-10-19T17:49:39+00:00
    Yeah this is bollocks. It was working at some point too and decided to stop.
    2023-10-23T06:32:45+00:00
    Hi Microsoft,
    I believe forcing the users to use exclusively prescribed devices is perhaps also open to layer attack. Sooner or later someone will show up and sue you for it. For this reason, I recommend that we all make this service available for other devices, such as true-wires headphones.
    2023-10-28T18:13:58+00:00
    I am also having this issue and have read every single forum Q&A about this and did alllll of the steps to try and fix and they still aren't working. My last pair worked JUST FINE, and I upgraded and the new pair will not work at all but works with all other apps including Zoom, GoTo Meeting, Google meetup, everything. PLEASE FIX THIS as our team uses Teams primarily for everything.
