I am not able to copy and paste Teams message with Time and sender name
2024-08-15T14:41:51+00:00
I am not able to copy and paste Teams message with Time and sender name. I was able to do it a week ago. I want to copy text with time and sender name. same issue on both Desktop and web version
Microsoft Teams | Microsoft Teams for business | Chats | Group chats
    2025-02-25T19:59:33+00:00
    Thanks for sharing, Jessica. That's new to me, too. A bit tedious, but better than nothing.
    2025-03-04T14:45:25+00:00
    As of the latest update, 'holding the mouse while using shortcuts to copy' no longer works. Is there another way now to include the time stamps?
    2025-03-04T14:53:34+00:00
    The removal of the Date-time and user name also affected me very much..
    The workaround which was provided previously by other users here (Thanks) (holding mouse button and then pressing Ctrl+C) no longer worked starting version 25017.203.3370.1174.
    I was a silent user watching this problem from far, I decided to sign-in to just to chirp in on one workaround I found by accident...
    Procedure:
    • On the chat..
    • Click out of the typing field box,
    • Press Ctrl+A
    • Press Ctrl+C
    This copies the entire chat until the last Hidden texts..
    From there, I trim and format it with NP++ by finding "Today" and formatting from there..
    I know it is still a "around-the head solution" and has too much garbage data..
    It is a pity that Microsoft took a post from 1 person with 15 votes and removed a logical thing.. They should've weighed in the use-case scenario across the world (which I firmly believe requires the date-time and user fields for their daily work). This basically is telling about the type of people they have at work over there.
    Update: Here's an Excel formula sheet that I prepared, this cleans up the data a bit and helps me at least,
    Feel free to download and modify it as per your needs..
    Perhaps someone can take this idea further into a VBA that does this all from start to end without manual intervention
    How to use:
    • Copy paste the text dump to a text editor of your choice, trim out all previous conversation to the top which is not necessary for you.
    • Copy this ↥ shorter conversation
    • Paste the text conversation in Cell A7(Under the "Input" header), this way the conversation texts occupy one cell per row..
    • At Cell B2, type the full name of the person you are speaking to, (as appearing on the teams chat).
    • At Cell C2, type your full name, (as appearing on the teams chat).
    • Use slicer to exclude 0 (Zero) and [] (Double square brackets) from the table
    • The texts from G7 (under "Output" header) to the bottom are you conversations in a bit readable format..
    General note:
    I use 24Hour clock, so there is a possibility that this might not work for the people preferring 12H format.
    again, this is just a Excel spreadsheet with formulas, feel free to download and change it as per your needs..
    2025-03-04T16:15:56+00:00
    only way i've found is to go to Teams in a web browser and copy from there (using that terrible workaround) -- and, that quit working for a while yesterday, but then it started working again - not sure what MS is doing, but ...
    2025-03-04T16:19:24+00:00
    See the post by Jessica Gomez3 on February 25, 2025 or from Karthik-S today.
