In TEAMS, is there a way to set your work hours on the calendars?
2024-03-19T13:08:07+00:00
I am trying to set working hours on my TEAMs calendars. Is this possible? If so, how can I do that?
Thank you!
Deanna
Microsoft Teams | Microsoft Teams for education | Calendar | Manage calendars
    2024-03-19T15:28:53+00:00
    Hello Deanna H! I'm Gunasekar and I'd be happy to help you with your question.
    Yes, you can set them on Outlook calendar.
    “In this article http://answers.microsoft.com/thread/0c07b2da-9c99-473b-88d4-1cf3d2171f35 SergioA2020 provided the steps to change/set your work hours in New Teams."
    You need do this change in Outlook, after it you should log-out and log-in in Teams.
    To change or set your workdays and work times in Outlook, do the following:
    1. In your Outlook calendar, click the File tab, then Options>Calendar.
    2. Under Work time, choose the Start time and End time, of your work day.
    3. Select the days of the week that you work, and clear the days that are not a part of your work week.
    4. Choose the First day of the week, that you start working.
    5. To change the first week of the year, choose an option in the First week of year list.
    6. Click OK to confirm the changes.
    If the calendar doesn't sync properly, then you should remove all Teams cache files.
    Give back to the Community. Help the next person who has this issue by indicating if this reply solved your problem. Click Yes or No below.
    I hope this information helps. If you have any questions, please let me know and I will be happy to help you further.
    Best regards,
    Gunasekar N
