Switched from Outlook to G Suite
2024-10-10T14:41:04+00:00
Hi
We have shifted from Outlook to G Suite. Will this have any issue in the login credentials of Ms Teams ?
Example, :
In office 365 admin center , we had given indianschool.com as domain name. With the switching do we have to make any changes in the domain name in office 365 admin centre.
Thank you in anticipation.
Microsoft Teams | Microsoft Teams for education | Sign up and Sign in | Other
    2024-10-10T22:31:19+00:00
    Hello Poornima Nair,
    Good morning!
    Thank you for publishing in Microsoft Community. We are happy to help you.
    Switching from Outlook to G Suite can indeed affect your login credentials for Microsoft Teams, especially if your domain settings are not updated accordingly. Here are a few key points to consider:
    Domain Name in Office 365 Admin Center: If your domain name (indianschool.com) remains the same, you generally don't need to change it in the Office 365 admin center. However, if your email addresses or domain settings have changed, you will need to update these settings to ensure seamless access to Microsoft Teams1.
    Login Credentials: Ensure that your users' credentials are synchronized correctly. If your organization uses Single Sign-On (SSO) or federated identity, you might need to update the identity provider settings to reflect the new G Suite configuration. This should be handle by Google support to ensure the credentials are synchronized correctly
    DNS Settings: Verify that your DNS settings are correctly configured to point to the appropriate services. This includes updating MX records, CNAME records, and any other relevant DNS entries3.
    Microsoft Teams Sign-In: If users encounter sign-in issues, you can use the Microsoft Support and Recovery Assistant to diagnose and fix common problems. Reference : Fix Teams sign-in errors - Microsoft Teams | Microsoft Learn
    We look forward to your reply. We will continue to assist you based on the information you provide. I sincerely appreciate your patience and cooperation.   SincerelyEben Ezer Tres | Microsoft Community Moderator
