Additional meeting and call-related features and issues within Microsoft Teams for Education
Just retried today, and now API connection has been automated:
- Connect your third-party device to your desktop.
- Open Teams for desktop.
- Select Settings and more
in the top right of Teams, then select Settings
> Privacy. - Select Manage APIunder the Third-party app API section.
- If Manage API is greyed out, an IT admin from one of the accounts you used to sign into Teams has disabled third-party device pairing.
- Turn on the toggle next to Enable API.
- Join a Teams meeting and press any button on your third-party device.
- You will see a window to Allowor Blocka new connection request. If the API token is empty, select Generate to generate a new one.
- Tapping Allow means the third-party device will pair and can interact with Teams; it will be added to the Allowed apps and devices list.
- Tapping Block means the device will not be allowed to interact with Teams and will be added to the Blocked apps and devices list.
- Remove a previously paired device by tapping Block.
- Re-pair a previously blocked device by tapping **Forget.**Once done, you can pair the device again.
