Using Microsoft Teams on macOS, including installation, features, and compatibility
Hi Mary,
I had a similar issue and was able to solve it in the System Preferences.
- System Preferences>Security & Privacy
- Click on the Privacy Tab
- On the left scroll bar find and click on Accessibility
- You will need to click on the padlock and enter your admin credentials
- Make sure Microsoft Teams is there and checked
I hope this helps you.
Best of luck,
Joe
