Using Microsoft Teams on macOS, including installation, features, and compatibility
January 30th and still having issues. Just purchased a brand new Mac.
Any updates on the team issues on Big Sur ?
Hi all,
I recently installer MacOS Big Sur in my Macbook Pro from scratch (not upgrading from previous installation). Once the system was working, I installed the Office 365 suite from App Store and MS Teams from microsoft.com (Teams does not exists in the App Store). All software is working properly EXCEPT Teams. After installation and launch, I keeps freezed in the "Loading Microsoft Teams" view.
I have uninstalled and reinstalled the package several times, restarted the machine, etc, but it still does not work.
Are there any procedures or fixed I should perform? Does Teams actually works on Big Sur?
Thanks.
This is the only solution that worked for me!!!!!
Thank you soo much!
Same Problem...
MacBook Pro 13"
Procesos M1
Mac OS Big Sur
teams does not open
Thank you Nik.
Unfortunately, none of the methods worked to make Teams work. It keeps on this view. Are there any others methods I could try? This is mi work laptop and Teams is the main remote tool we use. I am considering to downgrade MacOS to make it work.
Thanks for the help.
Same here, i'm running macOS Big Sur 11.2
Unfortunately, I can't even open Teams on my iPad Pro, it keeps crashing.
