Using Microsoft Teams on macOS, including installation, features, and compatibility
Hi Rodrigo,
I'm Nik, an independent advisor here to assist you with this.
- Quit Microsoft Teams.
- Delete files in following folders.
“~/Library/Application Support/Microsoft/Teams/Application Cache/Cache”
“~/Library/Application Support/Microsoft/Teams/blob_storage”
“~/Library/Application Support/Microsoft/Teams/Cache”
“~/Library/Application Support/Microsoft/Teams/databases”
“~/Library/Application Support/Microsoft/Teams/GPUCache”
“~/Library/Application Support/Microsoft/Teams/IndexedDB”
“~/Library/Application Support/Microsoft/Teams/Local Storage”
“~/Library/Application Support/Microsoft/Teams/tmp” - Restart Microsoft Teams.
If it does not work, you may try clearing the cache of your app.
Sign Out and Quit Microsoft Teams then
to remove the cache credentials.
See following steps:
- Go to Finder > Applications > Utilities.
- Select Keychain Access.
- Look for the login credential to MS teams, then delete it.
Regards
Nik
