Additional features, settings, or issues not covered by specific Microsoft Teams categories
This is not a Teams issue. It´s happening with Cisco WebEx as well.
So I keep having an issue where people are losing network connection while on teams meeting while using a dock. We have Lenovo USB-C docks, but when you are connected to a teams meeting with a network cable plugged into the dock. It drops the meeting, it could be 5 mins into the meeting, 20 mins into the meeting. I cannot find a connection to the length of time it gives you online before you drop.
It only happens to you if you have a USB-C Lenovo Dock, plugged into a Lenovo laptop, with a network cable plugged into it. If you pulled the cable and work off wifi it NEVER has a problem.
I have done dock driver updates, dock firmware update.
Any ideas? has anyone else had this problem?
Are you sure? We didnt noticed this drops for example in Zoom and Google Meetings :( So if anybody can confirm is it only Realtek Ethernet port issue?
Yes, absolutely. When using wifi or ethernet directly on the laptop the problems do not occur.
Hi Microsoft-Support,
at my organization, we have the same issue. So it would be very helpfull, if the Microsoft technician cloud give us an update to this thread.
Greetings
Dirk
Dear MS Support Team ,
Could you please help us regarding releated issue ?
