MS Teams and network drops
2020-10-28T16:52:50+00:00
So I keep having an issue where people are losing network connection while on teams meeting while using a dock. We have Lenovo USB-C docks, but when you are connected to a teams meeting with a network cable plugged into the dock. It drops the meeting, it could be 5 mins into the meeting, 20 mins into the meeting. I cannot find a connection to the length of time it gives you online before you drop.
It only happens to you if you have a USB-C Lenovo Dock, plugged into a Lenovo laptop, with a network cable plugged into it. If you pulled the cable and work off wifi it NEVER has a problem.
I have done dock driver updates, dock firmware update.
Any ideas? has anyone else had this problem?
    2021-01-08T10:28:50+00:00
    Same issue here,
    Lenovo USB-C docking station, on both a Lenovo Yoga and Microsoft Surface laptop.
    As soon as I pull the network cable and use the Wifi, there are no problems at all.
    2021-01-08T11:48:16+00:00
    Same issue here. Elitebook 840 G6 in combination with dual philip243B monitors.
    If I find a acceptable workaround, will udpate
    2021-01-08T13:15:24+00:00
    This is starting to sound like a netsock issue 🤦 with W10
    2021-01-08T18:51:32+00:00
    It's not, it's Teams Video utilising Ethernet over USB-C (with a high probability that it occurs when USB-C is handling multiple peripherals, such as multiple video channels)
    2021-01-08T23:39:36+00:00
    I'd love to know if anyone using Hangouts has this issue. I want to rule out that it's teams but I don't have much to compare it to. I turned on logging as well with teams and checked all the logs but it doesn't seem to show much other than a disconnection occurred.
    It also seems that the usb-c docks are realtek audio and ethernet.
