Additional features, settings, or issues not covered by specific Microsoft Teams categories
Hi Crystal Young (clyoung),
Welcome posting in the forum.
I noticed you mentioned “If you pulled the cable and work off wifi it NEVER has a problem.”, to exclude the dock problem, if possible, you may change another dock to see if there are any differences. Besides, always make sure you are using the latest version of Teams, go to your profile picture in the upper-right of the Teams app and select Check for updates. Updates typically install in the background if they're available.
Also, if you have this issue on Teams desktop app, you may try to sign in Teams web app to see if this issue still happens, vice versa.
Moreover, try to make a test call to verify if your internet configured correctly. For how to make a test call please see Make a test call
Regards
Grace
