Additional meeting and call-related features and issues within Microsoft Teams for business
Guys, please relax! Ha-ha-ha! I know you are frustrated and upset. But I know Teams works great. So it must be something on your side. It could be anything: hardware, camera model, computer type, version of Teams, Internet connectivity, VPN tunnel, split VPN tunnel, your proxy server, router, cable modem, anything! Just try to change one thing at a time. Or everything all together. For instance just grab another computer, totally different model, and try Teams there. If it works - then look what could be causing it.
If you check this thread back few month you can find our investigation and some hints that camera could be a culprit. In fact when I grabbed some hi-end USB external camera with separate power supply I got the same problem. But historically (for almost 10 years now) I use Microsoft Studio WebCam 1080P and it works really well. At some point it was a problem that video image was dark in Teams but with firmware update on the camera this issue was fixed.
So try something and share your results. Use another computer. Try Laptop. Try Surface Pro. Try something. It must be something on your machine. Do you have 3-rd party antivirus? Do you have bunch of old garbage installed? Why don't you wipe your disk and install fresh Windows 10 version 20H2, put clean latest Office 365 ProPlus and try again? I can almost assure you will get it working if you just try something...
