MS Teams keeps on switching to 'Away' even though I am still online
2020-08-14T10:13:42+00:00
For the past couple of weeks, Teams has been changing my online status to 'Away' (one of the yellow indicators) even though I am still online.
It will happen if I am using another application outside of Teams (multiple screens in use), or if I minimise Teams and also actually happens just 3 minutes after I post an IM in Teams !!
It's extremely irritating as statuses are an essential indication as to whether someone is about or not. And currently it looks like I am not, even though I am actively using my PC.
Windows 10  Enterprise 2004. Teams Ver: 1.3.00.19173 (64bit), last updated 28/07/2020 which also ties in with the length of time that I've noticed the error.
Mr. Trust_A 4,820 Reputation points
2021-08-05T20:53:26+00:00
Hi Brian-W & Everyone,
Early this year, a Microsoft employee provided an update on this topic in this similar thread: MS Teams changing constantly to "away" status
Please feel free to start a new post if you are still experiencing the issue so that the community users can render fresh help.
We will close this topic for now. Thanks for your understanding!
Regards,
43 additional answers
    2021-07-08T15:16:11+00:00
    This is not an acceptable answer! You're saying if you're writing an email or working in whatever software you do your job with you have to stop doing your job every 5 minutes to go in and change your availability to show that you're online. Obviously you can go into the app and switch your availability online. Everyone knows that. I also find it amusing that you show how many people found that it was helpful but I bet you won't show how many people didn't find it was helpful I bet you it's thousands of people.
    2021-07-08T20:28:53+00:00
    This is literally the only viable solution and it does work as part of my daily start up as well. Thanks for sharing this work around while Microsoft ignores all of us :)
    2021-07-08T20:33:17+00:00
    Not sure if you are getting upset with deevirgo? They have offered up a work around that actually does work so you DON'T have to reset status every 5 minutes. You have mis-read there suggested solution.
    2021-07-09T10:02:51+00:00
    This works (great! thanks!) . . . but it is also a terrible reflection on Microsoft that we're having to use this method (basically staying in a fake meeting all day) to make basic functionality work the way it should.
    Reminds me of my first car . . . . with a passenger window held closed using scotch tape . . . . . . 😆
