How To Fix Microsoft Teams Audio?
2020-04-15T16:36:21+00:00
I am on Windows 10 on an HP laptop and my audio for Microsoft Teams keep cutting off every now and then. It comes back on, it goes back off. I would say it does it for 15 seconds and then I get a minute of a good audio. The video works fine too, but there's no audio while the video shows the person is clearly talking.
Moved from Windows 10  / Calling and messaging
Microsoft Teams | Microsoft Teams for education | Meetings and calls | Audio and video
2021-08-17T03:13:17+00:00
Hi All,
This is Alan Wu from Microsoft Office 365 forum team.
I am very glad to have this chance to reply here. Well, for teams audio related issue, I believe dear customers may try the following suggestions:
  1. Check the band width which has been stated clearly in Prepare your organization's network for Teams - Microsoft Teams | Microsoft Docs.
  2. Make sure your driver and audio device are workable. For more information, you can refer to My microphone isn't working in Teams - Office Support (microsoft.com).
  3. Update your Teams client to the latest version.
  4. Isolate it is not the recipient side issue. I mean, supposing you are having a Teams call with another user and got this problem, please make sure the issue is not coming from that user's side.
At last, dear customers, as the similar/same issue may be caused via different factors since your environment like OS, client version, network, etc are different. I suggest our dear customers who are having the issue can post a new thread in our forum so that our engineers can better handle it. Here we can avoid some confusion from the original post. Thanks for all very much.
Regards,
Alan
2021-03-22T20:44:49+00:00
[Update] Ignore all that I said below regarding audio drivers. I noticed exactly the same issue while using Zoom. The real issue turned out to be WiFi. Even though the WiFi speed showed a respectable 30-40Mbps, switching to Ethernet solved the issue forever.
Ignore the part below:
I had the same issue and was able to solve it after some investigation. In my case, the cause boiled down to an audio driver that my Samsung PnP monitor (used as extended screen) was installing. Somehow Teams allowed itself interference from this audio driver, even though it was not selected in Teams settings. Here are the steps I would recommend, especially if you are using an external screen / microphone / webcam etc.:
  1. Go to Control Panel > Device Manager
  2. Expand Audio inputs and outputs
  3. Right click the audio driver(s) that you do not use, and click Uninstall.
(Just disabling did not make the problem go away; uninstalling was required.)
Now the problem should go away. If you detach and reattach the monitor / device to your laptop, the audio driver will show up again, and you will need to uninstall it again.
TIP: If you are not sure which audio driver is being installed by your monitor / device, physically disconnect that device, open Device Manager and then plug in the device. You will see the Device Manager refresh and the new audio driver that shows up is the one being added by  your monitor / webcam / mic / device.
85 additional answers
    2021-03-10T20:55:07+00:00
    I am also having this issue with an HP laptop.   I do not have this problem when Use teams from my Ipad, Macbook or Phone.
    I have updated all drivers and made sure I have 0 Bluetooth devices connected.
    Did you sort this? I am having the same problem ...
    2021-03-10T20:56:47+00:00
    I have exactly the issue which is described above. for several weeks now and it is very annoying, especially during client virtual communications.
    My laptop is a LENOVO P52s Core i7 16GB RAM (powerful desktop machine)
    1/ I have this issue and I can say for sure that it is network/location independant :
    I have issue in the office when I am connected to the company network
    I have the issue with of without being connected to VPN
    I have also the issue at home with my personal fiber connection (1Gbits)
    2/ the audio goes away for about 10s EXACTLY every 5mn (I recorded this during various TEAMS session and this time never changes. It is always every 5mn)
    3/ I do not have htis issue with any other similar application (WEBEX, ...)
    4/ it only affects AUDIO flow, not VIDEO flow
    5/  My colleagues do NOT have this issue, while I am seing this issue my neighbour did not experience it during the same TEAMS meeting. So it seems only my machine has the issue but it runs the same company applications
    The IT department from my company uninstalled and reinstalled TEAMS yesterday but the issue is still there.
    So there is definitely an issue related to TEAMS. I looks to me like an audio buffer overflow which resolves itself after 10s .
    Please investigate and resolve this issue
    Hi
    What did microsoft advise ? The audio issue is driving me nuts and my work insists on using it. HP laptop, Windows 10 educational version
    Any tip and tricks would be helpful. Thanks
    Please tell me if you resolved this? I am having the same problem and it’s also driving me completely nuts!!!
    2021-03-10T21:21:26+00:00
    Unfortunately not. Still having This issue and it’s incredibly frustrating!
