Microsoft Teams will not start and stuck at "Loading Microsoft Teams..."
2020-06-23T19:53:51+00:00
Good day,
I just downloaded and installed MS Teams (Teams_windows_x64.exe File version 1.3.0.15561 93.5MB) on my son's HP Laptop i3-6100U CPU @2.30 Ghz 6GB RAM running Windows 10 64-bit.  No other apps are running (I do have Microsoft 365 installed), however after the white window that says "Installing Microsoft Teams..." then switches to say "Loading Microsoft Teams" with the 3 counting dots moving, but that is all it ever does.  The screen never gets to the login screen (I installed the same on my wife's laptop which works fine as is on my desktop PC).  It just sits at that loading screen endlessly.
When looking at Task Manager, I do see the MS Teams process which has 4 sub-processes - 1 says Loading Microsoft Teams, and 3 says Microsoft Teams. None are showing any CPU % or Disk % usage.  The only items that show activity are Memory (105MB total) and 0.2% GPU
I have already uninstalled 3 times, removed everything from %Appdata%\Microsoft\teams directory after each uninstall and rebooted several times after each. Result is the same after each install attempt.
As a point of reference, when trying to run Teams, the current overall CPU usuage is only 30%, Memory is 52%, Disk is 6%, and the laptop is running over wifi and does connect to internet (as I tested Edge and it works fine, as does Outlook and all other Office apps.
Please help?
Thank you
-Michael
2020-11-20T08:50:27+00:00
I might have a fix!
NB: DO NOT install Teams as stand-alone app. As i understand it conflict with the one provided with Office via 'Teams Machine - Wide Installer'.
First check if you find C:\Program Files (x86)\Teams Installer folder with two file in ('setup.json' and 'Teams.exe').
If YES, this fix should work for you.
1) UnistallTeams and all the Office suite (mine is 365 provided by University IT but as i understand it should work also for other IT provided suite and for private licence)
  1. Go to File Explore (or Win+R) and paste *%appdata%\Microsoft*
  2. Find 'Teams' folder and delete it.
  3. Restart your PC.
  4. Install again your office suite, login and update it (open Word -> Account -> Update Options -> Update now)
  5. Restart your PC again.
  6. If after restart Teams login automatically appear it should be fixed and just login. If not, follow the next steps
  7. After you fully update Office, open File Explorer and go to C:\Program Files (x86)\Teams Installer
  8. Execute 'Teams.exe' and a new installation and login process should start.
10) ENJOY
2021-01-22T17:08:32+00:00
For me it was just :
  1. uninstall Teams
  2. click on C:\Program Files (x86)\Teams Installer\Team.exe
58 additional answers
    2021-11-02T03:25:24+00:00
    The same happened to me but what worked for me was changing compatibility to Windows 7
    To do this,
    Right click on teams,
    Select properties
    Select Compatibility
    Over there check the box saying "Run this program for compatibility mode for"
    And the Box below must gray out.
    By default, it must be written windows 8.
    click on that box and select windows 7.
    Now click apply and close properties.
    Now start teams and enjoy!
    If that didn't work,
    follow the video given below https://www.youtube.com/watch?v=xaqs5PE3614
    2021-11-02T03:26:32+00:00
    Yu could have used teams web while that period
    2021-11-02T03:27:42+00:00
    I have the same specs with Just 8gb ram and a i3 7th gen
