MS Teams Helper using up >100% of CPU MacBook
2020-05-22T10:17:30+00:00
Since the latest update of MS Teams (current version 1.3.00.9271 updated on 07/05/20) on a MacBook (early 2015), every time I now join a Teams call, the Microsoft Teams Helper is using >100% of CPU and causing the laptop to overheat. I have disabled the GPU acceleration as seen on some other message boards but this has no impact, and could do with a fix for this ASAP.
Many thanks in advance.
    2021-05-05T11:21:49+00:00
    Same with me! SOOOO annoying- any updates on this?!
    2021-05-11T00:42:51+00:00
    My impression is that Teams 1.4.00.7175 is considerably better. It still makes my fans spin up, but it doesn't seem to make the rest of the system slow to a crawl. Does anyone else have the same experience?
    2021-05-11T01:02:03+00:00
    Im running 1.4.00.8872. It was last updated on 27/4/21.
    Sadly no change.
    2021-05-24T08:22:20+00:00
    Yes, this really is bothersome. My computer grinds to a stop when I launch Teams, and it uses up 131% of my CPU (!). I considered buying a new computer, but realised after reading from you guys that it's not the computer that is bad.
    2021-05-31T15:17:49+00:00
    I have the same problem. Teams helper with video consumes 276% of the processor.
    As soon as you stay in call but without video, the power consumption goes down to 17,2 %..
